Volumio Version:2.873
Hardware: Raspberry pi 2
DAC:USB
When I tried to add a playlist, I got the message that the filesystem is read-only.
Apparently this is for saving the sd card.
I can not update the mpd.conf file in SSH either.
Can anyone tell how I can temporarily change the filesystem in read-wrie to be able to apply my changes?
Thank you in advance.
Something is not right here. Did you check the checksum of your downloaded image? How did you transfer it to the sd card? Did you leave Volumio running for a reasonable time (say 5-10 mins) after first boot. I think I would try again with a freshly flashed image.
