I am running Volumio on a Pi4 with Digione, connected to a Schiit Modi 3, with RCA cable. I am not quite sure how I can confirm that Volumio/the Pi is outputting 100% volume? It seems kinda low to me. What kind of settings are correct?
Should I2S dac be on or off when using Digione with Modi 3? Should I enable mixer, or will the selected “none” make sure the output is 100%? I can not select hardware, even though I have tried resetting everything to factory settings.
Hi! Let me tell you tell you something about my things about volumesettings and volumediffereneces:
My Pi is a 3B using also a Digi+. DAC is a MusicalFidelity, connected by RCAcable. Trust me, sounds better than USBconnection! I2S is a MUST, otherwise you can’t select the DAC! MixerType “none” sets 100%volume!
BUT: playing music, you can be sure THERE ARE DIFFERENCES IN VOLUME!
playing music from different ripped CDs will cause differences in volume! The music on CDs has not really the same volume. Test it with a CDPlayer…
playing internetradio is louder that music from the ripped CDs… Technical things, that you could’t change…
using Spotify-Connect-Plugin? Take a look at the setting for that! There is a volume-setting! Turn it LOUD or the Spotify-music is low in volume and sounds HORRIBLE! The “volume normalization” in spotify or volumio didn’t really work successfull! Tested it!
AND REMEMBER: it makes no sense buying other hardware. You will always get the same “issues” and “problems”. But they aren’t really. Do the “right” settings and here you are - enjoy the music!
