Hello, I’ve been running Volumio for several years on 3 RPI3B with Hifiberry and allo amps and I2S DACs. Now I bought an SMSL D6 USB DAC but it doesn’t show up on the list of output devices.
Can I load the driver for the DAC onto the Volumio SD card on my Windows PC? I’m wondering if this might be a solution since I know nothing about Linux to load it directly on the pi. Any other ideas to try?
Thanks for your help. I tried the process that’s described but it doesn’t show up on the list of options, only headphones and HDMI. The DAC has its own power and the pi is powered by a 2.4A power bar. Does it need to be higher?
The DAC shows up now, it may have been because the DAC was set to optical source input for the TV. It shows up when I switch the input to USB. Or maybe it was the power supply. Anyway, I’m sure the new 3 amp power supply will be an overall improvement. Thanks everyone for your help in fixing it.
