Hi all. I am new to Volumio and just got it set up. I have two questions. 1. Can I control the volume with my iPhone? It goes to full volume now when playing streaming radio. 2. I have a Qobuz account but can’t figure out how to find it when in Volumio. Thanks much. Dennis
You need Volumio Premium, then you log in to My Volumio - and then go to Settings / Sources where you will find the login to Qobuz a bit further down in the list of sources.
Qobuz integration requires a Volumio Premium subscription. Open the main menu (3 bars at top left) and select Sources. Scroll down and you will find a field to enter your Qobuz login. After successful login, scroll down to the Sources Visibility section and make sure that Qobuz visibility is turned on. Now on the Volumio main screen, when you tap on Browse (folder icon at lower right), you should see a selection for Qobuz.
For volume control, open the main menu and select Playback Options. Under Volume Control > Mixer Type, select hardware or software (available options depends on your system). You should then be able to use the volume control at the bottom right of the screen.
