How to get the Spotify plugin working
Maybe it is not the good way, but to power off all my devices Rpi 2,3,4, primo, sparky… I pull the power plug from the wall😬. For years… And no specific problem.
Hello i recently had to make new volumio image and it doesnt support plugins without account in this version. At least it doesnt support the official volumio library, but it seams like i can install plugins manually, but like on this site doesnt work anymore so am asking for help with this. When i try the link said here it my rspi say 404 not found. Is anywhere some new link?
You need an account with V3 of volumio.
Local Volumio 3 builds won’t be able to use the plugin repo as the necessary myVolumio component is missing and there is no workaround for it.
The myVolumio part can only be built on the volumio build server.
Though you should still be able to install manually.
