how to get internet access when connect to Volumio hotspot?
when I connect my cell phone to Volumio hotspot for play control. Volumio connect to router with lan wire. however cellphone can not have internet access.
The hotspot is only intended to allow a temp connection, it’s so you can configure the R Pi for your wifi network. Once you’ve configured the R Pi to use your wifi the hotspot is no longer needed.
Just to add that if your device is connected to the lan, just connect your smartphone to the WiFi of your router and use the IP address to use Volumio
