Jurjen
1
I have 2 raspberry’s with volumio 2.502 working.
They have different names and fixed different IP adresses. One wired and one via wifi.
I can only see the last one used, or the last one that booted in volumio app, or spotify connect. (volumio apple app on iphone 5s)
How can I get to see both of them in the volumio app and spotify, so that i can chose where to play music?
When i access them via the web interface, i can also see only the one i access, not the other on the main screen.
There seems to be some issue with the multiroom with 2.502 (cannot-change-device-multi-room-selection-after-t11110.html) in the meantime, bump down to the lower version to check if that solves your issues for now.
Spotify Connect
I’m guessing your using volspotconnect2 - if so are you using the device discovery mode? (Shared device) or do you supply your credentials?
Jurjen
3
I’m using volspot connect 1.7.5 the newer versions do not work very well. Discovery mode, inog log in credentials in volumio app
