I just built my music streamer with a Pi4B, Hifiberry Dac 2 HD, and the official Pi Touchscreen. Working great and sounds even better than previous build with a lesser DAC. The only thing is the quick timeout on the touchscreen. I am too inexperienced to know how to go and tell the plugin to disable the timeout or change the duration. Hints?
Never mind. I figured it out. I expected the settings to be on the screen where I selected to install the plugin. Didn’t know I had to access the settings on the Installed Plugins page. Set timeout to 0 and good to go.
