Is it possible to disable internal wifi adapter from RPi3 and to use an USB external adapter ? How can I do that?
Thank you!
Thank you!
@SonosKiller is absolutely right, it’s the best way to explicitely turn-off internal Pi3 (PiZeroW, not sure about Pi3b+) wifi for good.
Now, even if you do not do that, an external wifi dongle should still take precedence over internal once plugged-in (assuming proper driver/firmware is available in Volumio).
Thank you Master @macmpi
Only quoting the best !
(had the statement saved but I didn’t remember who wrote it)
All credits to @macmpi
Thank you all!
