How to create a new Page on Volumio 2
Earlier this year I build a Pi DAC running on Volumio 1.55 with an ener314-ir and its lirc library.
This version was easy to custom and allowed me to add new pages such as taking the control of my amp.
Today I installed the latest version of Volumio + updated all other libraries I usually used.
Lirc works perfectly I can control the amp via ssh but the new structure of volumio 2 is very different from the previous.
My question is how can I create a new page and add a link into the main menu without playing with the add-on features?
This page will be like a form with different button and when you click on one of them it will execute a shell command exec($value) or shell_exec($value)
For example:
[code]
<?php include("inc/marantz_control.php"); ?> Power On [/code]
marantz_control.php file
<?php
if(isset($_POST['lirc_command'])){
$input=$_POST['lirc_command'];
        switch ($input){
                case "poweron":
                exec('sudo SEND_ONCE Marantz KEY_POWER');
                break;
                case "poweroff":
                shell_exec('irsend SEND_ONCE Marantz KEY_SPLEEP');
                break;
                case "airplay":
                shell_exec('irsend SEND_ONCE Marantz BTN_MISC');
                break;
echo $input."test";
Could I add a simple page within the folder /volumio/http/www/app/themes/volumio/assets/static-pages and a script into /volumio/http/www/app/themes/volumio/scripts
But I might have to follow the MCV framework from AngularJS to add a new page.
What I think I have to do:
New controller
New page
update the volume menu
[]Where to find the file mainmenu.json?
]Where should I add the page and the controller?
Where to start?
Thanks!
lirc-ir.txt.zip (1.1 KB)
No idea where I should start?
May I edit the menu without breaking the all things? (image attached).
Where is the Controller of the menu I could edit to add a new entry?
Where can I storage new JS controller?
Where to storage my new template?
My previous script what based on PHP
Can recycling my script?
Thanks :slight_smile:
The best way is to create a plugin, and a page UI to manage it. Please have a look at : https://volumio.github.io/docs/Plugin_System/Plugin_System_Overview.html
Thank you balbuze.
I definitely need to spend some time to get it done as a plug-in :slight_smile:
Yes and it would be so easy to reuse, for you or other user ( with some adaptation) :wink:
Let us know if you need help!
I won’t hesitate if I need help michelangelo! I’m not the best in coding but I have some skills in web dev.
Let’s see how far I can go with Angularjs as it’s new for me but not the MVC concept.
Don’t worry, no need to code with angular. We made a plugin system which should work for you!
volumio.github.io/docs/Plugin_S … rview.html
I’m reading the pages :smiley:
A simple way to do this is to simply make use of lirc_web (github.com/alexbain/lirc_web). Change default portnumber 3000 in config and you’re running!
