I think I would need some help. I am trying to connect my Volumio with my nextcloud, which is not on the same network.
Is it even possible?
Sorry, you can’t with standard Volumio.
You might make it with some custom scripting, but have no idea how
Thanks for the reply. Is there a plan to add this? Or as a add-on?
Cheers
