How to auto control TV volume to specific level
I have a high end Plasma TV BUT old. Because of the nuisance of ADS I keep adjusting my TV volume Down Then Up …You get the picture.
I need to automate volume correction to a specific volume I am comfortable with ( which can be adjusted)
Can you help me with this annoying problem.
How did you connect your TV to device with volumio?
I need recommendation for what hardware should I buy… I have never used volumeio before
I am assuming that it can be done using volumio hardware
Sorry, I think, volumio can’t resolve your problem. Try search for “volume normalization”, maybe some one create device for this. But I didn’t see any such device. Maybe, try connect tv into your pc’s sound card. In PC make volume normalization, and send sound from PC to amplifier.
Thank you for putting me in the “right” direction. I will pursue this avenue…
At least I am in full control with my PC driving the TV.
