How to add webradio as favorite?
When I attempt to add a web radio as favorite, the current song it is playing got added instead. And after a while, it got removed automatically. Is it possible to have a shortcut to my favorite web radio without having to search and sort the full list of web radio?
And when I add a web radio into a queue, after a while, the next track get played. How long do web radio get played before it skip to next track in the queue? Can this be configured?
had no problems with that so far.
I added my own webradios in “my web radios”, then you can add them to your favourite ones by selecting “add to radio favourites” after pressing the context menu (the three dots).
When i start a webradio once, it runs for hours until i quit it.
There are a few stations that stop the stream after some time, perhaps you have one or more of those.
hope this helps
Gemstone
I had the same problem. you have to stop the stream, than add it to your favorites. If it is playing you get the name of artist and song
