How to access music stored on a USB drive (SSD)
Hi, I have installed Volumio3 on an old mini PC (Celeron 1017U), and it’s running fine. However, I can’t access music stored on a USB (EXT4, gpt) drive:
In the Volumio GUI, the drive doesn’t show up, searching in “My music” results in 0 files.
However, when I log in via ssh, I can access the drive, create & delete files, etc. So it is mounted correctly (at /media/UUID). Hence, my question: Does the drive, or folder (there’s not only music, but also other stuff on the drive, therefore a few subfolders) needs to have a special name? I did search the FAQ, but I couldn’t find if there needs to be a special naming.
Thank you very much!
have a look at this post
It will answer your question
Hi gkkpch,
thank you very much for your reply! Ahh, I actually didn’t find that requirement when I searched - sorry for that. Sadly, it still does not work: I labeled the volume to issd, now the drive gets mounted to INTERNAL, instead of USB as before:
lsblk -f
NAME   FSTYPE   LABEL        UUID                                 FSAVAIL FSUSE% MOUNTPOINT
loop0  squashfs                                                         0   100% /static
sda
|-sda1 vfat     boot         9CC8-09A7                              88.1M    48% /boot
|-sda2 ext4     volumio      eb55ffab-19d3-41c1-ba5a-6467611e98a1    1.3G    56% /imgpart
`-sda3 ext4     volumio_data 5150c78d-bb55-4219-a857-d922a8e325ff
sdb
`-sdb1 ext4     issd         2e583573-eac7-44c0-9aa2-451ac1ac606f  854.2G    48% /data/INTERNAL
or paste code here
I can access all my files via ssh, but the volumio gui still can’t find them. Is there e.g. a systemdlog that could help?
please have a look here
most probably the disk does not have a partition table
It does have a partition table, gpt type. Maybe something went wrong when I ceated it? (But I never had problems with gparted before, and my Debian work machine didn’t complain ever - the drive is old.)
fdisk -l says “Disklabel type: gpt”
As Volumio is Debian based, I’m puzzled. Do you know where the configuration settings for the Volumio behavior are located? Perhaps the label restrictions etc. can be simply switched off.
@j.steeg
You need to submit a log, otherwise this becomes just a game of guessing.
