You’re already looking at the CLI if you can see the above, but unless you have a keyboard connected then you obviously can’t access it. You can access the same CLI remotely by using ssh:
BUT, I suggest you start again from scratch with a verified image download (check md5sum), a different sd card, and leave the device after boot a good few minutes to sort out various set up procedures before doing anything more.
Gotcha. Thank you.
Yep I was following the official quick start guide, installing latest version from scratch. I think my card is no good will try a better one.
