Just upgraded to virtuoso. How do I use Tidal native? I read that it should appear in my music, nothings there…?
Help.
Help.
go to menu, under sources scroll down until you see the Tidal option. Need to enter user name and password. Once you are successfully logged in, the tidal app should show up after a few seconds in the browse page.
Thanks,
The Tidal login didn’t appear until I re-imaged Volumio on my SD card. Works now.
Does the native Tidal let you stream directly from the Tidal app? Or am I only capable of airplay to the Rpi from the Tidal app?
Thanks.
