How do I add text to GUI?
Is it possible to place some text on the front playback screen?
Which file using SSH do I need to edit.
Regards,
Mark :slight_smile: :slight_smile: :slight_smile: :slight_smile:
Edit the Files in /var/www/templates
In your Case That Would be: indextpl.html
E.g : sudo nano /var/www/templates/indextpl.html
