Hi
I am wondering how I access the empty part of my SD card. If I look at the partitions I see
sudo fdisk -l /dev/mmcblk0
[sudo] password for volumio:Disk /dev/mmcblk0: 29.7 GiB, 31914983424 bytes, 62333952 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x415547f5Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 * 1 125000 125000 61M c W95 FAT32 (LBA)
/dev/mmcblk0p2 125001 4882812 4757812 2.3G 83 Linux
/dev/mmcblk0p3 4882813 31116287 26233475 12.5G 83 Linux
i.e. 3 partitions, with the 3rd the largest. I then look at the mounted partitions and I see
df
Filesystem Size Used Avail Use% Mounted on
/dev/mmcblk0p2 2.4G 1.3G 945M 57% /imgpart
/dev/loop0 364M 364M 0 100% /static
overlay 14G 131M 13G 2% /
devtmpfs 494M 0 494M 0% /dev
tmpfs 509M 70k 509M 1% /dev/shm
tmpfs 509M 5.0M 504M 1% /run
tmpfs 5.3M 4.1k 5.3M 1% /run/lock
tmpfs 509M 0 509M 0% /sys/fs/cgroup
tmpfs 509M 46k 509M 1% /tmp
tmpfs 509M 0 509M 0% /var/spool/cups
tmpfs 21M 537k 21M 3% /var/log
tmpfs 509M 0 509M 0% /var/spool/cups/tmp
/dev/mmcblk0p1 63M 60M 3.6M 95% /boot
/dev/sdb1 123G 40G 84G 32% /media/RIP
/dev/sda1 251G 150G 101G 60% /media/DIGIONE
tmpfs 102M 0 102M 0% /run/user/1000
So the big partition is not mounted. There is a /data/INTERNAL directory but nothing is mounted there, although I note its shared in the smb.conf! I have done this on a virgin install of the latest Volumio version.
Many thanks
Andrew
