Hi Volumio community,
I like volumio and it’s great. The last update bug was not so nice, but now, i’m on 2.141.
All work fine, but I have problems with the security.
My kids are on the same lan, and I want to protect my Lan from creating a new open Hotspot, if the Kids plays with the settings.
I don’t need WiFi, so I can completly disable the Wifi support.
Is there a way from disable WiFi from the console, so it’s not accessible any more?
Another thing is, that if I add a network share, I can later open the options and read the password.
Can please add password protection to the options, so that my Kids or perhaps a hacker on my net, can use the information from my volumio to go deeper into my network?
Thanks a lot
Erik
