HiRes playback issue
Why does Tidal switch from high resolution, e.g. 192/24 to 44/16, for example for a Miles Davis Kind of Blue album? It plays the first track at 192/24, then switches to 44/16 for the second. If I start the second track again, it plays 192/24 again. Volumio 3.779, Sound Quality: Hi-Res.
@Marco_Melziade @DED
I can confirm this behavior, MPD reports the wrong information. Using an external DAC shows all songs as 192/24.
Doing the same in the native tidal app (Phone), res stays on 192/24
Thank you for reporting the issue.
I can confirm the incorrect behavior on my side as well. I’ve noted this and assure you it will be a priority for us to investigate and address as soon as possible.
Thanks again for bringing this to our attention.
Best regards,
Davide
VOLUMIO TECH SUPPORT
