High-quality project
Hello everyone,
I’m building a new media player.
It’s based on a 4GB Raspberry Pi 5 with a 128GB SSD and an 11.9-inch Waveshare display for the main unit.
I’ll be using a StationPi by Ian Canada to neatly separate the “dirty” from the “clean” parts.
I’m using a FifoPi MA for reclocking and a dual PCM1794A DAC.
The I2S input/output LEDs are working fine, as are the clock selection and play LEDs.
But I have no sound—do you have any ideas?
I’m also having an issue with the Spotify plugin and Volumio 4, which requires me to re-authorize it every time I boot up.
Thanks to
@ThomasBuzet Take a look at the link; you need to do this to get sound out of the Dual PCM 1794A.
@michel8166
Thanks,
I checked out that link and tried it, but without success.
Last night I found a site that mentioned replacing the timers and going with the 20/22 models.
I might just go for it—about €50 at Audiophonics for both…
I much prefer to adapt the hardware rather than the software, which might stop working after updates…
If it doesn’t work, I’ll have to find a DAC that’s on par with the Fifo. I wanted to do the right thing and go for something high-end, but I didn’t anticipate this problem!!!
Too bad—I love the sound of the 1794; it’s warmer and less digital than the chips Sabre
@ThomasBuzet, That is strange that it doesn’t work.
I will take a look tonight at a friend’s streamer for which I made that PCM 1794A; it has been running like that for years with upsampling via FusionDSP.
As soon as I know more, I will let you know.
I kept digging into the issue—as a reminder, I wasn’t getting any sound out of my dual PCM1794A.
Since I love the sound of this DAC, I really wanted to get it working.
I tried using a DAC HAT, my trusty Inno-Maker Pro, but the FIFO on the GPIO pin doesn’t carry the MCLK. However, it did confirm that it works.
So I went with a hybrid setup: all connections on GPIO except MCLK, which is on UFL.
Bingo—it’s running at 192 kHz/24-bit with the original clocks and switch settings.
Now I need to find the culprit; I suspect a UFL connector on the board because my wires are fine according to the ohmmeter.
Now I need a case and to design a nice layout!
