I moved from moode to volumio and I got problems with 192/24 files @rpi2. CPU usage is like 70-80% and the audio cuts out time to time. CPU usage with moode is 5-10% with the same file. Rpi2 connected to avr with hdmi. System Version 2.201, mpd 0.20.6.
[spoiler]![](https://www.upload.ee/image/7223072/volumio2.jpg)
[/spoiler]
Hm… make sure software volume control is off and no other software based filtering/equalizing is going on.
Straight through playing should not cause such a load. Only when any sofware processing like re-sampling, etc. is going on.
Verzonden vanaf mijn iPhone met Tapatalk
It’s a clean install updated to 2.201, volume disabled, resampling disabled.
IMHO this is what happens:
- Moode uses a newer kernel (which we just upgraded to in our test releases) which enables HDMI to play frequencies up to 24/192
- Your version of Volumio uses a kernel where HDMI output is limited to 48k
- Because of this, Volumio resamples your audio to 48k, with an high quality algorithm, causing the high CPU load
- You can try the new version, and let us know if that’s still the case (see: help-needed-test-the-new-updater-t7057.html)
With v2.233, avr shows:
Audio
Sound Mode Stereo
Input Signal PCM
Sample Rate 48 kHz
Format 2/0/.0
That confirm my hypothesis, but unfortunately it seems that latest volumio still resamples to HDMI.
To be honest I never optimized HDMI since few people use it, so I am a bit lost here.
But I’ll do a bit of research and then come back to you
Thanks! I think hdmi is the cheapest option for beginners with avr and better than cheap hat/usb cards. So it would be nice to have it working.
