Hello, everyone,
I’m sorry for possibly duplicating the topic (I could’t find it in the forum, though), but does Volumio support the HiFiBerry’s Wireless Remote Control, please? (So, is it worth buying?)
THANK YOU!
Hello, everyone,
THANK YOU!
Should work using tiggerhappy: https://community.volumio.com/t/keyboard-shortcuts-with-triggerhappy/4826/14
Hi, @gvolt ,
THANKS a lot for the good news!
And how would it get installed, please?
SORRY, amateur asking.
Open “/etc/triggerhappy/triggers.d/audio.conf” with nano (editor):
sudo nano /etc/triggerhappy/triggers.d/audio.conf
Edit the content as described by @adaptiman here.
To exit nano and save the file hit Ctrl+x then y and Enter.
systemctl restart triggerhappy.service
THANK YOU very much for the Step-by-Step guide! Much appreciated by an IT-layman.
I’ll try it soon, I hope.
All the best!
