HifiBerry - WebGUI
Hello!
Today I downloaded the release from sourceforge and try to start the I2S module for my Hifiberry over the WebGUI.
The problem was that, I couldn’t figure out why, snd_soc_hifiberry_dac was not added to /etc/modules.
Best Regards
Florian
Hello!
I have added HiFiBerry DAC to my Raspberry PI. I don’t know where I can get the files, that I need to start I2S Driver. Because the activation using WebUI was not successful. It would be wonderful to find here a workaround description! Maybe something like copy these Files to this directory. Modify this config file like …
Kind Regards
ONormahl
Hello!
  1. Login to your raspberry with ssh (e.g. ssh pi@192.168.0.xxx)
  2. take a look at your /etc/modules (e.g. less /etc/modules) it should look like that
snd_soc_bcm2708
snd_soc_bcm2708_i2s
bcm2708_dmaengine
snd_soc_pcm5102a
  1. if not… make it look like this with
cat >/etc/modules <<EOF
snd_soc_bcm2708
snd_soc_bcm2708_i2s
bcm2708_dmaengine
snd_soc_pcm5102a
EOF
  1. do a reboot (e.g. sudo reboot)
  2. enjoy music!
Regards
Florian
Thanks! The original “modules” file has only one row with “snd_soc_bcm2708”…
Now it work’s fine!
Greetings
ONormahl
Yep didn’t notice that the modules name had changed… Anyway good work Florian!
