HifiBerry MiniAmp
Hello.
I am having trouble getting the volume control to work with Hifberry miniamp and a Raspberry Zero. I contacted HiFiBerry. They were extremely helpful and this is what they came back with.
Thanks,
HiFiBerry
HiFiBerry team (HiFiBerry)
Dec 6, 13:26 CET
Yes. It seems, that the onboard sound card is still configured. It is possible that this is used instead of the MiniAmp. I recommend contacting the Volumio developers. They might be able to tell what to do to disable this.
What is the output of “aplay -l”?
My Response:
volumio@volumio:~$ aplay -l
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 1: sndrpihifiberry [snd_rpi_hifiberry_dac], device 0: HifiBerry DAC HiFi pcm5102a-hifi-0 []
Subdevices: 1/1
It’s working with volumio2 on my pi Zero W with Hifiberry Miniamp.
My settings are:
Soundcard: Hifiberry Dac
Mixer Type: Software
I am running the same configuration (hifiberry miniamp on a raspi zero W) and I am having problems. I am running the latest release of volumio (as of today, Release 2.129). I am getting 100% volume occasionally - too much for this amp :slight_smile: and the rest of the time no sound at all. Sometimes, between reboots, “hardware” shows up as an option in the mixer - most of the time it is only “Software”.
The fact that things are so irreproducible is quite frustrating.
So: you say that your exact same setup works. did you do anything else than downloading and flashing the OS?
Cheers,
Chris
I experience the samwe problem of the amplifier on a raspberry pi 2B
Has anyone had problems with sound output with the HiFiBerry MiniAmp and the Volumio 3 release?
(For me it was working with Volumio 2)
Yeah, I gave up. Not the amp but the HiFiBerry DAC+ ADC PRO (HW 1.0.1).
Some times it works, If I set mixer to none, reboot, then set to software, I need to repeat it after every reboot.
If I set it to hardware Volumio starts stuttering and finally crashes.
At some point the irritation won and I took a hammer and modified the DAC.
how is the mini amp issue?
I was thinking of buying it to play music in the bathroom.
rpi Zero W + hifiberry miniAmp
thank you all!!! (L)
It works with this workaround:
  1. flash sd card with actual volumio version (3.631 at the moment)
  2. Configure Volumio / sd card in a classic Raspi (not Zero) - Raspi 3b in my case - without choosing DAC
  3. Put sd card in the Pi Zero
  4. Choose Hifiberry DAC (NOT AMP!) and volume control to “Software”
  5. Have fun :wink:
