HiFiBerry+ Light can't change volume!
Hi, i have HiFiBerry+ Light installed on my Pi3 and I set my DAC to HiFiBerry DAC.
It works great but I can’t change the volume…
Or you can only change the volume with 3.5 audiojack on the pi3?
This DAC does not provide a hardware volume mixer. See https://www.hifiberry.com/products/dacplus/
You have to use a software volume control in order to set the volume.
Faceplam, to bad…
Next time, will better check the spec’s before buying :wink:
