Just got my Hifiberry Digi !
It was a little bit difficult to make it run
Just want to share my experience:
I thought I just have to enable I2c drivers in Web Ui as drivers for hifiberry now included in the last Volumio release. But it was not running.
After severals coffees and words that I cannot repeat here
Thanks for this. I’ve been having troubles, so I have been attempting your fix. I get to rpi-update and get this:
GnuTLS: A TLS warning alert has been received.
Unable to establish SSL connection.
!!! Failed to download update for rpi-update!
!!! Make sure you have ca-certificates installed and that the time is set correctly
Not really sure what to do at that point.
EDIT: I should add that I tried the two fixes on the rpi-update site to update time and install ca-certificates and still have the issue.
EDIT2: Missed this step when installing rpi-update.
