Hifiberry Digi volume control fail
I used Raspberry Pi 2 with a Hifiberry Digi and latest Volumio 2, and Volume option by default
mixer type -> none
mixer control name -> none
Playback works fine, but volume was always at 100%, I can’t control the volume with UI
I tied to change Volume option to used software control, but in this case I don’t have any music
mixer type -> software
mixer control name -> software volume control
Have miss something on my setting?, modify configuration in ssh terminal ?
Have you any workaround to configure or solve this issue?
Thanks in advance for your Help.
Volumio it’s a great tools
Same here with rpi3 and hifiberry dac+
Verzonden vanaf mijn iPad met Tapatalk
Did you make sure that you rebooted after changing the type to “software control”?
That was the missing piece, thnx chsims1!
