Great! Thanks!
So far I was only able to use Hifiberry Digi+ Pro on runaudio with updated kernel with use of pacman. It worked with local music on USB, but spotify app did not work after upgrade .
On newest Libreelec it worked as well, but since it is dedicated for movies it has poor interface for music playback and I do not like it.
I would also be interested in this. I have a digi+ pro sitting idle.
Add me to the list, please. Iām also interested in Volumio being compatible with HIFIBERRY DIGI+ PRO.
Iām also interested in volumio thatās working with de Hifiberry digi+ pro.
Verstuurd vanaf mijn HTC 10 met Tapatalk
I would also be interested in testing this release. Donāt like moode and would rather switch to volumio .
Is there a test release available? I would very much appreciate access to it.
-Fredrik
Canāt wait to try Volumio with the Digi+ Pro
Why specifically for RPI3? Runeaudio for example has released a beta (0.4) which also can be used for RPI2 in combination with the Digi+ Proā¦
![](https://community.volumio.com/letter_avatar_proxy/v4/letter/v/58f4c7/40.png)
TioFrancotirador:
michelangelo:Volumio boots with an initramfs, which needs to have the same kernel version as the kernel we use.
So, rpi-update will break your installation. Thatās why also we canāt change kernel: updater will not work anymore.We will need however to change the kernel in the near future. So when this will happen, we will release Volumio with hifiberry digi+ support
Michelangelo can you create experimental volumio build with newest kernel for rpi 3 + hifiberry digi+ pro?
Thanks man. I did not know such build exits. It actually works!
![](https://community.volumio.com/letter_avatar_proxy/v4/letter/t/f17d59/40.png)
Vhond:
TioFrancotirador:
PiCoreplayer and moodeaudio works also with hifiberry Digi+ pro
![](https://community.volumio.com/user_avatar/community.volumio.com/michel8166/40/455_2.png)
Yeah, but those are logitechsquezzebox based. I do not like complications. I like simplicity. Chromecast audio is of best usability if you are only using spotify or tidal. Wish one day someone will embed chromecast capabilities into his rpi build. In such case you could use native tidal and Spotify apps for navigation.
We were already thinking on doing that, probably next week, dated: 29 Mar 2017, 14:28
Is there some progress for this release?
Hello everyone. I wanted to ask Michelangelo when it will be released the version that supports hifiberry digi + pro.
Thank you all for the excellent work.
Hi there !
Same thing on my side.
Any idea for a release date ?
Hi everyone, I saw that version 2.141 was released. Do not understand if the kernel was changed? Does hifiberry digi + pro work with this release? Has anyone ever tried it? Iām trying tonight. Thank you.
please keep us posted about compatibility. i am waiting to order a Digi
![](https://community.volumio.com/letter_avatar_proxy/v4/letter/l/8dc957/40.png)
The Digi+ works, itās the Digi+ Pro that doesnāt (yet).
So āstillā not in the just released version 2.141??
No it still doesnāt work I have tried it last week.
I tried the Digi + Pro with version 2.141 and it does not work for me.
I expect a new version with the updated kernel for digi + pro.
