Hi
I am new to Volumio. But I am having troulbe getting Hifiberry DAC2+ to wotk with Volumio.
I found some similar problems in the forum. I changed the config.txt and set the mixer to Software, got Audio from my lodcal NAS. But I can’t get Tidal connect to play. Tidal Connect shows up in the Tidal interface, get any errors, but the music will not start/play. I have registered my Tidal account in Volumio.
I have downloaded the current image today.
Does Volumio have a support line? It is a fairly expensive subscription if you have 2 device, not none of them works.
