I have ‘upgraded’ from a PI2B as I wanted to get WiFi connectability but failed to get them working with V’ 3.396, getting the ALSA error below. The DAC worked fine with the old PI2B, just no WiFi.
Some suggests please ?!
This is a standard well working DAC for the rPi3. In fact I use the same hardware to support this forum.
Which settings did you select in “Playback Options”, please show screenshot.
like this:
please copy the results of the following command:
cat /boot/config.txt
Thanks for the reply.
I had taken it all apart so had to re-assemble it to answer your questions, and the bl**dy thing started to work !!!
So you’re bl**dy well to go
Cheers anyway.
