Volumio Information
Volumio Version:2.882
Hardware: Raspberry Pi4
DAC:HiFi Berry DAC2 HD
I’m getting now sound from the HiFiBerry DAC2 HD. I have a USB DAC plugged in and I do get sound from there when I select. I’ve recreated the Volumio endpoint with the DAC2 HD installed but still no luck. Below is the live output log, it looks like that even though the DAC is selected, Volumio can’t recognise it. Any help would be greatly appreciated. Thank you
Regards,
K
Starting Live Log...
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
Device not found: 1. Exiting.
BYE
vtcs.service holdoff time over, scheduling restart.
Stopping Volumio Tidal Connect Service...
Starting Volumio Tidal Connect Service...
Started Volumio Tidal Connect Service.
info: Executing endpoint tc_getconfig
info: CoreCommandRouter::executeOnPlugin: tidalconnect , onGetConfig
Expression 'alsa_snd_pcm_hw_params_set_period_size_near( pcm, hwParams, &alsaPeriodFrames, &dir )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 924
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround21
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
BYE
BYE
BYE
info: CoreCommandRouter::volumioPlay
UNSET VOLATILE
info: CoreStateMachine::play index undefined
info: CorePlayQueue::getTrack 2
info: CoreStateMachine::startPlaybackTimer
info: [1621848267336] ControllerTidal::resume
info: CoreStateMachine::setConsumeUpdateService mpd
info: ControllerMpd::resume
info:
---------------------------- MPD announces state update: player
info: sendMpdCommand play took 5 milliseconds
info: ControllerMpd::getState
info: sendMpdCommand status took 2 milliseconds
info: sendMpdCommand playlistinfo took 2 milliseconds
info: ControllerMpd::pushState
info: CoreStateMachine::syncState stateService play
info: CoreStateMachine::syncState currentStatus pause
BYE
info: ------------------------------ 13ms
BYE
BYE
info: CoreCommandRouter::volumioPause
info: CoreStateMachine::pause
info: CoreStateMachine::stPlaybackTimer
info: CoreStateMachine::servicePause
info: CoreCommandRouter::servicePause
info: [1621848272047] ControllerTidal::pause
info: ControllerMpd::pause
info: sendMpdCommand pause took 54 milliseconds
info:
info: sendMpdCommand status took 3 milliseconds
info: sendMpdCommand playlistinfo took 4 milliseconds
info: CoreStateMachine::syncState stateService pause
info: ------------------------------ 18ms
BYE
