Have just purchased one of these boards before discovering the previous incompatibility threads from a year ago.
Have tried a couple of the mentioned fixes but am still getting the ALSA error when running on Pi4B with latest Volumio. Did the community eventually give up on trying to solve this?
Welcome to the community. The HiFiBerry DAC2 HD has indeed been a bit of a special case. What you are seeing is not a generic ALSA problem but tied to the kernel driver support for the DAC2 HD.
Before anything else we need to know exactly what you are running. Please confirm:
Exact Volumio version number (from System Info page).
Whether it is Volumio 3 (Buster) or Volumio 4 (Bookworm Beta).
Where you got the image from (official download site or some other repo).
Complete hardware details:
Raspberry Pi 4B model and RAM size
Power supply make and rating
Storage type (microSD, SSD, NVMe, USB stick)
Any other HATs or devices connected besides the DAC2 HD
Without that, it is impossible to tell if you are on a stable release, the current Beta, or an older build. There is no such thing as “latest” unless you provide the version string.
I had the same problem with my hifiberry DAC2 HD and it took me months to find the fix. I believe the problem is related to the i2s bus. The bus was not correctly synchronizing the up to 3 i2c bus lines.
On the Raspberry Pi 4 I added the following to the /boot/userconfig.txt:
dtoverlay=i2smaster
dtoverlay=hifiberry-dacplushd (you would use the overlay for your sound card here. This should be in the /boot/config.txt when you installed the DAC but, just to be safe)
After that I rebooted the pi and it has worked perfectly ever since.
One other note, the hifiberry/pi combination can be rather slow scanning your media directory especially if you are using the SDCard or USB. During that update time I have also seen the ALSA error. Word for thought. Good luck!
I was also researching into the HiFiBerry DAC2 HD (just like @thom) when I found several of the threads in here.
Reading the comment of @nerd about the DAC2 HD being “a bit of a special case” made me re-think my plan…
I am currently planning to run Volumio 4 on a rPI 5 (8GB) together with a HiFiBerry DAC2 HD and connect that to my hifi system. In the forum I already found multiple threads on this DAC and the different problems people were having (especially with the DAC2 HD and Volumio 3).
Is there any information on whether the DAC2 HD will reliably work in Volumio 4 on a rPi5 (or is there anybody in the community running this setup) ?
I don’t want to fiddle around with the setup, so if the DAC2 HD is still a bit unreliable under Volumio 4, I would rather “downgrade” and get a HiFiBerry DAC2 Pro to circumnavigate possible problems.
Would that be a more stable setup, or would you recommend using a totally different DAC altogether ?
