I had a much older version of Volumio from about two years back. Everything was working but I seemed to look the Spotify Icon. I therefore upgraded to the latest version. Everything appears to be working except that I now have no audio coming from my HiFiBerry DAC Plus. The audio settings appear to be the same as before the upgrade.
What might have done wrong and how do I troubleshoot?
aplay -l returns
ALSA lib conf.c:3523:(snd_config_hooks_call) Cannot open shared library libasound_module_conf_pulse.so
ALSA lib control.c:1373:(snd_ctl_open_noupdate) Invalid CTL hw:0
aplay: device_list:277: control open (0): No such file or directory
card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 3/3
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
card 2: sndrpihifiberry [snd_rpi_hifiberry_dacplus], device 0: HiFiBerry DAC+ HiFi pcm512x-hifi-0 [HiFiBerry DAC+ HiFi pcm512x-hifi-0]
Subdevices: 1/1
The output is incorrect due to change in the way devices are numbered.
To fix, select an other output such as headphone and save. Now select your Dac, you may have to enable i2s.
Oops I posted this accidentally on a different post
Alas no joy. I tride rebooting between each change and then also doing an upgrade which then returned the following error
volumio@volumio:~$ sudo apt upgrade
[sudo] password for volumio:
Reading package listsā¦ Done
Building dependency tree
Reading state informationā¦ Done
You might want to run āapt-get -f installā to correct these.
The following packages have unmet dependencies:
libpam-systemd : Depends: systemd (= 215-17+deb8u8) but 215-17+deb8u7 is installed
systemd : Depends: libsystemd0 (= 215-17+deb8u7) but 215-17+deb8u8 is installed
E: Unmet dependencies. Try using -f.
volumio@volumio:~$ sudo apt-get -f install
Correcting dependenciesā¦ Done
The following extra packages will be installed:
systemd systemd-sysv
Suggested packages:
systemd-ui
The following packages will be upgraded:
2 upgraded, 0 newly installed, 0 to remove and 84 not upgraded.
2 not fully installed or removed.
Need to get 0 B/2259 kB of archives.
After this operation, 463 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
debconf: delaying package configuration, since apt-utils is not installed
dpkg: warning: files list file for package āupmpdcli-qobuzā missing; assuming package has no files currently installed
dpkg: warning: files list file for package āupmpdcli-gmusicā missing; assuming package has no files currently installed
dpkg: warning: files list file for package āupmpdcli-tidalā missing; assuming package has no files currently installed
(Reading database ā¦ 27442 files and directories currently installed.)
Preparing to unpack ā¦/systemd_215-17+deb8u8_armhf.deb ā¦
Unpacking systemd (215-17+deb8u8) over (215-17+deb8u7) ā¦
dpkg: error processing archive /var/cache/apt/archives/systemd_215-17+deb8u8_armhf.deb (āunpack):
trying to overwrite ā/usr/share/dbus-1/system-services/org.freedesktop.systemd1.serviceā, which is also in package systemd-shim 9-1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Processing triggers for dbus (1.8.22-0+deb8u1) ā¦
Processing triggers for man-db (2.7.5-1~bpo8+1) ā¦
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Is there anything else I can try before performing a fresh install?
The only plugins I have installed (which are also actuive and configured) are:
System information
Touch Display
Spotify
Backup & Restore
GPIO Buttons
I can see Spotify playing but hear nothing. I have tested my AMP by playing my computer through it so I know that that is still working.
What ever I try, and I m quite familiar with Volumio and a raspi,: Failed to open āAlsaā: Failed to open ALSA device āvolumioā: Invalid argument.
I donāt get where the āvolumioā is coming from. Did a fresh install and tried many options and after restart the same error over and over again.
I tried a dac+ and dac+ pro, both the error.
I attached an original Raspi 7" screen but that should not be a problem I guess.
With version 2 I had never any problem with these hats.
please post a picture of your HAT. Both DAC+ and DAC+ Pro are fully supported with Volumio3, if they donāt work on your side we should try to understand why
To make it working with Volumio, you should select HiFiBerry DAC Plus from the I2S list and then reboot.
I can see you connected some dupont cables on the GPIO header. Please try to remove them and verify if the DAC is working. Two of the dupont cables are connected to the PIN3 (GPIO2) and PIN5 (GPIO3), those pins are the I2C bus required for initializing the DAC, if the I2C signals are affected by the cable the initialization wonāt work, and you will get alsa error
