Hi, all, I have a new install of Volumio on a raspi0w with a Hifi Berry Amp2 , however i get no sound from it. I spent 3 hours yesterday looking around for any information for a solution i could find and finally gave up last night before posting on the Hifi Berry forms, who. responded with the obvious answer of selecting the “correct profile for the amp”.
I am hoping that someone with a similar setup who has it working can post their config, or let me know if this is just a bad board/bug in current release ect.
I do appreciate any and all help. thanks!
Go to playback options, enable I2S DAC, select Hifiberry DAC2
Restart
Let us know
did that 3 times across 3 re-flash’s of the SD card.
did not work
edit:
additional information that may be of use, the command aplay -l
returns:
card 0: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 1: sndrpihifiberry [snd_rpi_hifiberry_dacplus], device 0: HiFiBerry DAC+ HiFi pcm512x-hifi-0 [HiFiBerry DAC+ HiFi pcm512x-hifi-0]
Subdevices: 0/1
We don’t have an hifiberry amp 2 here to test, so not sure we can help.
Your best bet is trying all the hifiberry settings until you find the correct one…
Let us know
this is interesting, i just moved the SD card to my Rpi3 and the Hat is working
