I might not be the most objective testimony out there but…
Some reasons:
Better spotify integration
Better sound (that’s IMHO, of course)
Easier to connect to a wireless network
Easier to mount a NAS
You can see all albumarts
You can browse by artists, album or genres, also in a nice grid view
The UI is waaay more beautiful
We’re a very proactive community
But… I would be really happy if you could test by yourself. And I will be really glad to see if you think that Volumio is better than Rune, and if yes, why…
So far for me at least, Volumio simply doesn’t work.
Roon is very easy to configure for a variety of hardware without having to be a Linux expert.
I had Roon up and running in nothing flat, using the HDMI port as the sound output. Changing to a DAC connected via USB is about as easy as it gets.
Volumio doesn’t seem to list all the sound output options in the provided drop down, only PCH.
I’d love to actually hear what it can do, but so far, nothing. Perhaps when it is installing and detecting hardware it could actually locate the HDMI sound option since it doesn’t seem to have a problem providing video via that same HDMI connector.
I think you’re confusing two different sogtwares
I assume you’re using an X86 PC, right? If yes, to set the hdmi, could you tell us what kind of motherboard\PC you have?
If people would only try first before claiming it does not work
Plug an external DAC into a USB port and … … it shows up in the list.
Then you can hear what Volumio sounds like…
