I’m trying to setup Raspberry with Volumio. Here’s my progress.
Hardware:
- Raspberry Pi Zero
- Audiophonics DAC Sabre ES9023 I2S DAC
- Micro USB hub with RJ45 (Terminus Technology Inc, 4-Port HUB + Kontron DM9601 Fast Ethernet Adapter)
- USB Wifi dongle Realtek RTL8188CUS 802.11n WLAN Adapter
Here’s the wiring :
[code]I2S :
Orange: MCLK /
Yellow: GND -> pin 39
White: DATA -> pin 40
Red: LRCK -> pin 35
Black: BCK -> pin 12
Power:
Black: GND -> pin 6
Red: + 5V -> pin 4[/code]
Volumio 1.55
It doesn’t boot. If I replace the boot folder on the microsd card with the files from github/raspberry/firmware it boots. But the ethernet and wifi doesn’t work, if I type ifconfig -a I only get “lo” interface.
Raspian
Ethernet and wifi work out of the box.
Volumio2 RC1
It boots and ethernet is working. Wifi seems to work, I can enter my WAP2 key, it says “connected” but if I remove the lan cable it losts the connection.
I can access the interface on my pc. I change some things in the settings, access the files from my PC and copy one mp3. But it randomly crashes with this message :
unable to handle kernel paging request at virtual address
If I try to play an mp3 I get the message “cannot decode”.
The goal is to have Spotify on Volumio.
Thank you
