Hey all, I’m new to Volumio and am having an issue with Spotify. I had everything working with my Pi 3, then installed in a lectern style case with the 7" display. After that Spotify no longer appeared in my menu. I could see that it was installed, but I had no way to access it. I rebooted, re-installed the plugin, and finally did a reset. Before I did the reset I removed the app from my Spotify account. My plan was to simply start over and see if I could get it working. I did the reset, reinstalled the Spotify plugin, enabled it and tried to enter my login. It now errors out, but I see no way to fire off the Spotify app authorization process. Any help would be appreciated.
Thanks,
~Mark
