Hi.
I am reading up on the implementation of volumio. I used to run it off rpi, but at this point, I would like to explore option of how to:
Run DSD natively
Use NAS
I have been thinking of using micro pc for this but is there any other option available which would handle DSD files?
It is made in China. are you sure you really need one? Though its fanless mini pc that I tried with Volumio x86 OS. If you want a music server and NAS device(with SAMBA), this one will be good choice. Anyway, its optical out put is better that 3.5mm jack AUX.
Well i am planning to run spotify however would need usb hook up to dac for a more critical listening experience.
I do not know if I need to go fanless pc way or lets say rpi 4 would be enough to use it without any issue.
