Hello all,
I recently installed Volumio on my Raspberry Pi 4 with 2 GB of RAM. I also have a waveshare 5.5 inch AMOLED display connected via HDMI. When I try to install the Display Touch plugin I get the following error:
Downloading plugin at https://plugins.volumio.workers.dev/pluginsv2/downloadLatestStable/touch_display/volumio/buster/armhf END DOWNLOAD: https://plugins.volumio.workers.dev/pluginsv2/downloadLatestStable/touch_display/volumio/buster/armhf Creating install location Unpacking plugin Checking that the plugin is suitable for this version of Volumio The plugin can be used with this version of Volumio Checking for duplicate plugin Copying plugin to location Installing necessary utilities Re-synchronizing package index files from their sources Get:1 https://deb.nodesource.com/node_14.x buster InRelease [4584 B] Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB] Get:3 http://archive.raspberrypi.org/debian buster InRelease [54.2 kB] Err:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Undetermined Error [IP: 93.93.128.193 80] Get:4 https://deb.nodesource.com/node_14.x buster/main armhf Packages [786 B] Get:5 http://archive.raspberrypi.org/debian buster/main armhf Packages [400 kB] Fetched 460 kB in 1s (358 kB/s) Reading package lists... Reading package lists... Building dependency tree... Reading state information... 0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded. Installing graphical environment Reading package lists... Building dependency tree... Reading state information... Installation of xinit failed Plugin failed to install! Cleaning up... Removing dependencies Reading package lists... Building dependency tree... Reading state information... Reading package lists... Building dependency tree... Reading state information... Reading package lists... Building dependency tree... Reading state information... Reading package lists... Building dependency tree... Reading state information... Reading package lists... Building dependency tree... Reading state information... Reading package lists... Building dependency tree... Reading state information... Reading package lists... Building dependency tree... Reading state information... Package 'chromium-browser' is not installed, so not removed 0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded. Reading package lists... Building dependency tree... Reading state information... Package 'openbox' is not installed, so not removed 0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded. Reading package lists... Building dependency tree... Reading state information... Deleting /opt/volumiokiosk.sh Deleting /data/volumiokiosk Deleting /data/volumiokioskextensions Deleting /lib/systemd/system/volumio-kiosk.service Enabling login prompt Done Removing plugin directory /data/plugins/user_interface/touch_display Removing temporary directory /tmp/touch_display-ZPcSjpCk78 An error occurred while installing the plugin Error
Can anyone help?
