My Volumio is a Raspberry Pi B with a HiFiBerry Digi+.
This works very well, but it crashes way to often. I can’t put an exact time on this, but if I leave it on overnight, it’s crashed by morning. I restarted it before heading to work this morning, and it’s dead tonight. Unplugging and plugging in the power is sufficient to restore it to life.
What should I look for in trying to debug this? Is there a log or something that I could examine? Any ideas?
Unplugging without doing a proper shutdown risks corrupting the file system (which could be the cause of the instability). It’s worth burning a new image to see if this fixes things. It’s also worth trying a new sd card, as they have a limited life, and start doing strange things when they approach end of life. Another thing to try is replacing your power supply.
The log files are written to /var/log. However, I believe this is mounted on a memory-resident (tmpfs) file system, so does not survive a power cycle. You’d have to change /etc/fstab to mount it somewhere else if you want to look at the log files from before the crash.
when it crashes a file on the file system gets corrupted keeping the device from booting.
Most of these problem have a weak power supply as the root cause.
