Hmmm, that’s odd. What country are you located in? I wonder if it has to do with the country code, as the API delivers different results for different countries.
Also, can you post the contents of /var/log/volumio.org - that might give a clue.
Thanks skikirkwood for all the work on this plugin!
I have a sort of similar issue. I can display the contents of my own playlists and play them without any problems, but I cannot seem to display the tracks of other (public) playlists (I have no trouble finding public playlists). This is also the case for the tracks in the Genres & Moods and Featured Playlists.
I think it is only a matter of displaying the contents because if I choose to play such a public playlist, it will start playing and the tracks show up in the queue. This is the same for Genres & Moods and Featured Playlists (I cannot see the contents, but all show up in the queue when I select to play the list).
The funny thing is that I could see the tracks of a public playlist directly after I had copied your index.js file and rebooted the system, but that stopped working after a subsequent reboot…
Thanks Oleg, but it appears some others are having problems with featured playlists and genres and moods, so let me get those working for everyone first!
I have same issue as Yoast, but could never see featured playlists (but only My playlists). When adding such a playlist to queu it works and I can play the tracks. I am situated in Austria and have implemented the last index.js file.
It’s possible I had a version control problem. Can you install this new version of index.js and let me know how it works for Featured Playlists and Genre’s and Moods.
You can verify you are using the newest version by looking at /var/logs/volumio.log and after the message about the new Spotify access token you will see “Spotify credentials grant success - running version from March 23, 2019”
If you still have problems with Featured Playlists please post your log file here. Thanks.
first of all I highly appreciate your continuous efforts in trying to fix the issue. Thanks a lot for that.
My Playlists, My Saved Albums, My Saved Tracks, My Top Artists, My Top Tracks, My Recently Played Tracks and What’s New are working fine for me.
I’m located in Germany and with the last index.js you have shared I have following observations:
My Playlists, My Saved Albums, My Saved Tracks, My Top Artists, My Top Tracks, My Recently Played Tracks and What’s New all are working fine for me.
In Featured Playlist I can see the list of playlists, but opening a playlist is not possible, but I can play the playlists using the Play command from the options and I can even skip forward and backward.
In Genre & Moods I can enter into the list of Genres & Moods and even enter into one of the categories. Opening a playlist is not possible, but I can play the playlists using the Play command from the options and I can even skip forward and backward.
Ok, I think I finally have a release candidate of the Spotify plugin update with everything working and tested.
There was another bug in the browsing of Featured Playlists and Genres and Moods which I just fixed. Grab the latest from here:
here is a Spotify plugin with Refresh Token in settings UI. It is based on newest version index.js by skikirkwood.
Can you test it for me?
Before installation uninstall Spotify plugin and reboot system.
Type the following commands via SSH to download and install plugin:
wget https://github.com/majko96/volumio-plugins/raw/master/plugins/music_service/spotify/spotify.zip
mkdir ./spotify
miniunzip spotify.zip -d ./spotify
cd ./spotify
volumio plugin install
cd ..
rm -Rf spotify*
Updated index.js (with new refresh token) fixed playlist issues for me. Thank you skikirkwood & ma_sk1 for excellent work! Waiting for update installation via Volumio UI.
If I use Equalizer and audio jack trougth equalizer, plugin Connect2 not works.
It show my device but when I play from cell it receive the message, shows current selected from cell but not audio.
If I change Audio from Jack trougth equalizer to jack it works.
