audio_output {
type "httpd"
name "My HTTP Stream"
encoder "vorbis" # optional: vorbis or lame
port "8000"
#quality "5.0" # do not define if bitrate is defined
bitrate "128" # do not define if quality is defined
format "44100: 16: 1"
I did a sudo reboot
And I can not log in to 192.168.1.46: 8000 on windows 10 laptop
No no , just read your threads
Like to have some kind of central streamer and pickup streams in my other players
Have only done some test from my Pc with “Stream what you hear”
audio_output {
type “httpd”
name “MySK3Stream” #encoder “vorbis” # optional: vorbis or lame
port “8000” #quality “5.0” # do not define if bitrate is defined #bitrate “128” # do not define if quality is defined
format “44100:16:1”
sorry to resurrect thi topic, but im really struggling to make web radio to work. This lines added actually works, but it stops after a song, and it picks up again after manually browser refresh, to stop again after song is ended.
Is there any other, updated, way how to play own web radio via IP:8000 for Volumio now?
systemversion 3.512 hardware RPI3 B+ revision1,3
any help is much appreciated. Thanks
Edit: It looks that it picks up next song on Chrome,… Firefox does not,… its good enough now. I cant add URL to Winamp thou. Still cant figure out how to show Artist - Album - Song information on web.
