I only had one issue: some mp3 files were corrupted and set the indexer (database update) spinning forever, blocking on the bad song.
I was able to isolate the bad song: I’m available to share it as a test case if anyone is interested in fixing this indexing problem.
Here it is: drive.google.com/file/d/0B26fY8 … sp=sharing
Let me know when you’ve got it, and I’ll remove it.
I have another problematic mp3, but I did not try to isolate it yet among a set of 20 other files. Let me know if you need it as well: with a binary search it’ll take me 5 shots worst case to spot it
just a correction to my first post: my DAC is the Musical Fidelity V-DAC, and not the V-DAC II
Volumio does not seem to support volume control on my V-DAC with the hardware mixer.
Volume can be controlled, however, with the software mixer (to be set under menu/playback).
Overall, I’m satisfied. Can’t use WebRadios, though, (they just don’t play) but did not investigate further so far.
