The PC version has it by default, for arm devices you need to download the kiosk plugin.
Depending on PI or Odroid (the ones I have used) you might need additional configuration.
Therefore it would help if you told us what platform you are running Volumio on.
PI, Odroid, Beaglebone, Cubox, Sparky or a PC?
Well raspi-config would only cause harm, we have a dedicated Raspbian installation that would not work with it.
Ok, command line text does not look right, this seems a question for an up-to-day PI guy (I would have to dust a PI 3 here). @chsims1?
It was simply attached to my normal PC monitor by hdmi. Yes, I had installed the plugin. I saw all the normal bootup messages, and then the Volumio UI appeared (it’s done with Chrome, I think). Have you tried reflashing your card?
