I just burnt volumio v2.873 on a Rapi 2 and hooked it up to my AVR and TV via HDMI (no DAC, the AVR is my DAC)
When I turn the TV on, it shows the HDMI out from Volumio. But instead of the Volumio UI (currently playing, etc), it shows me the Linux console (with the login prompt)
I tried installing the Touchscreen plugin, but same thing: it shows the text console.
How do I get Volumio to show its UI over HDMI? Bonus points if I can also make CEC work with it.
Volumio was designed primarily as a “headerless” audio player. That is to say the GUI is reached through a mobile phone, a tablet, or any other browser-capable device running on your network.
It should be possible to use the Touchscreen plugin, as you have tried, to get hdmi output to a tv … have a Google, or here’s an oldish thread to get you going.
