Base of nuxii.fr/blog/2016/05/15/i2c-backpack-lcd-16x2/
& andypi.co.uk/2013/09/19/andypi-lcd-with-raspyfi/
sudo apt-get update
sudo apt-get install python-smbus i2c-tools -y
sudo apt-get install lcdproc python-mpd python-pip
sudo pip install mpdlcd
sudo wget -O /etc/mpdlcd.conf https://raw.githubusercontent.com/rbarrois/mpdlcd/master/mpdlcd.conf
sudo mkdir /home/volumio/raspdrivers
sudo wget -O /home/volumio/raspdrivers/hd44780.so https://github.com/wilberforce/lcdproc/raw/master/hd44780.so
sudo rm /etc/LCDd.conf
sudo nano /etc/LCDd.conf
[spoiler][code]# LCDd.conf â configuration file for the LCDproc server daemon LCDd
This file contains the configuration for the LCDd server.
The format is ini-file-like. It is divided into sections that start at
markers that look like [section]. Comments are all line-based comments,
and are lines that start with â#â or â;â.
The server has a âcentralâ section named [server]. For the menu there is
a section called [menu]. Further each driver has a section which
defines how the driver acts.
The drivers are activated by specifying them in a driver= line in the
server section, like:
Driver=curses
This tells LCDd to use the curses driver.
The first driver that is loaded and is capable of output defines the
size of the display. The default driver to use is curses.
If the driver is specified using the -d command line option,
the Driver= options in the config file are ignored.
The drivers read their own options from the respective sections.
Andy Pi version2 with GPIO14 and GPIO18 swapped to enable same pins for use with Raspbian
Server section with all kinds of settings for the LCDd server
[server]
Where can we find the driver modules ?
IMPORTANT: Make sure to change this setting to reflect your
specific setup! Otherwise LCDd wonât be able to find
the driver modules and will thus not be able to
function properly.
NOTE: Always place a slash as last character !
DriverPath=/home/volumio/raspdrivers/
Tells the server to load the given drivers. Multiple lines can be given.
The name of the driver is case sensitive and determines the section
where to look for further configuration options of the specific driver
as well as the name of the dynamic driver module to load at runtime.
The latter one can be changed by giving a File= directive in the
driver specific section.
The following drivers are supported:
bayrad, CFontz, CFontz633, CFontzPacket, curses, CwLnx, ea65,
EyeboxOne, g15, glcdlib, glk, hd44780, icp_a106, imon, imonlcd,
IOWarrior, irman, joy, lb216, lcdm001, lcterm, lirc, lis, MD8800,
mdm166a, ms6931, mtc_s16209x, MtxOrb, mx5000, NoritakeVFD, picolcd,
pyramid, sed1330, sed1520, serialPOS, serialVFD, shuttleVFD, sli,
stv5730, svga, t6963, text, tyan, ula200, xosd
Driver=hd44780
Tells the driver to bind to the given interface
Bind=127.0.0.1
Listen on this specified port; defaults to 13666.
Port=13666
Sets the reporting level; defaults to 2 (warnings and errors only).
#ReportLevel=3
Should we report to syslog instead of stderr ? [default: no; legal: yes, no]
#ReportToSyslog=yes
User to run as. LCDd will drop its root privileges, if any,
and run as this user instead.
User=nobody
The server will stay in the foreground if set to true.
#Foreground=no
Hello message: each entry represents a display line; default: builtin
Hello=" Welcome to"
Hello=" VOLUMIO 2!"
GoodBye message: each entry represents a display line; default: builtin
GoodBye=âThanks for usingâ
GoodBye=" VOLUMIO 2!"
Sets the default time in seconds to displays a screen.
WaitTime=5
If set to no, LCDd will start with screen rotation disabled. This has the
same effect as if the ToggleRotateKey had been pressed. Rotation will start
if the ToggleRotateKey is pressed. Note that this setting does not turn off
priority sorting of screens. [default: on; legal: on, off]
#AutoRotate=no
If yes, the the serverscreen will be rotated as a usual info screen. If no,
it will be a background screen, only visible when no other screens are
active. The special value âblankâ is similar to no, but only a blank screen
is displayed. [default: on; legal: on, off, blank]
ServerScreen=no
Set master backlight setting. If set to âopenâ a client may control the
backlight for its own screens (only). [default: open; legal: off, open, on]
Backlight=open
#BacklightInvert=yes
Set master heartbeat setting. If set to âopenâ a client may control the
heartbeat for its own screens (only). [default: open; legal: off, open, on]
#Heartbeat=open
set title scrolling speed [default: 10; legal: 0-10]
#TitleSpeed=10
The ââŚKey=â lines define what the server does with keypresses that
donât go to any client. The ToggleRotateKey stops rotation of screens, while
the PrevScreenKey and NextScreenKey go back / forward one screen (even if
rotation is disabled.
Assign the key string returned by the driver to the âŚKey setting. These
are the defaults:
ToggleRotateKey=Enter
PrevScreenKey=Left
NextScreenKey=Right
#ScrollUpKey=Up
#ScrollDownKey=Down
The menu section. The menu is an internal LCDproc client.
[menu]
You can configure what keys the menu should use. Note that the MenuKey
will be reserved exclusively, the others work in shared mode.
Up to six keys are supported. The MenuKey (to enter and exit the menu), the
EnterKey (to select values) and at least one movement keys are required.
These are the default key assignments:
MenuKey=Escape
EnterKey=Enter
UpKey=Up
DownKey=Down
#LeftKey=Left
#RightKey=Right
Driver sections are below this line, in alphabetical order
EMAC BayRAD driver
[bayrad]
Select the output device to use [default: /dev/lcd]
Device=/dev/lcd
Set the communication speed [default: 9600; legal: 1200, 2400, 9600, 19200]
Speed=9600
CrystalFontz driver (for CF632 & CF634)
[CFontz]
Device=/dev/ttyS0
Select the LCD size [default: 20x4]
Size=20x4
Set the initial contrast [default: 560; legal: 0 - 1000]
Contrast=350
Set the initial brightness [default: 1000; legal: 0 - 1000]
Brightness=1000
Set the initial off-brightness [default: 0; legal: 0 - 1000]
This value is used when the display is normally
switched off in case LCDd is inactive
OffBrightness=0
Set the communication speed [default: 9600; legal: 1200, 2400, 9600, 19200,
115200]
Speed=9600
Set the firmware version (New means >= 2.0) [default: no; legal: yes, no]
NewFirmware=no
Reinitialize the LCDâs BIOS [default: no; legal: yes, no]
normally you shouldnât need this
Reboot=no
CrystalFontz633 driver (for CF633 only)
[CFontz633]
Note: Use of this driver is deprecated, please use CFontzPacket driver
with Model=633 instead.
Device=/dev/ttyS0
Select the LCD type (size) [default: 16x2]
Size=16x2
Contrast=350
Brightness=1000
OffBrightness=50
Set the communication speed [default: 9600; legal: 1200, 2400, 9600, 19200, 115200]
Speed=19200
Currently this flag is not in use, there is no such thing as NewFirmware. ;=)
#NewFirmware=no
I want to reboot the LCD to make sure we start from a known state
Reboot=yes
CrystalFontz packet driver (for CFA533, CFA631, CFA633 & CFA635)
[CFontzPacket]
Select the LCD model [default: 633; legal: 533, 631, 633, 635]
Model=633
Device=/dev/ttyUSB0
Contrast=350
Brightness=1000
OffBrightness=50
Reinitialize the LCDâs BIOS on driver start. [default: no; legal: yes, no]
Reboot=yes
Enable the USB flag if the device is connected to an USB port. For
serial ports leave it disabled. [default: no; legal: yes, no]
#USB=yes
Very old 633 firmware versions do not support partial screen updates using
âSend Data to LCDâ command (31). For those devices it may be necessary to
enable this flag. [default: no; legal: yes, no]
#OldFirmware=yes
Override the LCD size known for the selected model. Usually setting this
value should not be necessary.
#Size=20x4
Override the default communication speed known for the selected model.
Default value depends on model [legal: 19200, 115200]
#Speed=115200
Curses driver
[curses]
color settings
foreground color [default: blue]
Foreground=blue
background color when âbacklightâ is off [default: cyan]
Background=cyan
background color when âbacklightâ is on [default: red]
Backlight=red
display size [default: 20x4]
Size=20x4
What position (X,Y) to start the left top corner atâŚ
Default: (7,7)
TopLeftX=7
TopLeftY=7
use ASC symbols for icons & bars [default: no; legal: yes, no]
UseACS=no
draw Border [default: yes; legal: yes, no]
DrawBorder=yes
Cwlinux driver
[CwLnx]
Select the LCD model [default: 12232; legal: 12232, 12832, 1602]
Model=12232
Device=/dev/ttyUSB0
Select the LCD size. Default depends on model:
12232: 20x4
12832: 21x4
1602: 16x2
Size=20x4
Set the communication speed [default: 19200; legal: 9600, 19200]
Speed=19200
Reboot=no
If you have a keypad connected. Keypad layout is currently not
configureable from the config file.
Keypad=yes
If you have a non-standard keypad you can associate any keystrings to keys.
There are 6 input keys in the CwLnx hardware that generate characters
from âAâ to âFâ.
The following is the built-in default mapping hardcoded in the driver.
You can leave those unchanged if you have a standard keypad.
You can change it if you want to report other keystrings or have a non
standard keypad.
KeyMap_A=Up
KeyMap_B=Down
KeyMap_C=Left
KeyMap_D=Right
KeyMap_E=Enter
KeyMap_F=Escape
keypad_test_mode permits one to test keypad assignment
Default value is no
#keypad_test_mode=yes
ea65 driver for the display in AOpen XC Cube AV EA65 media barebones
[ea65]
Device is fixed /dev/ttyS1
Width and Height are fixed 9x1
As the VFD is self luminescent we donât have a backlight
But we can use the backlight functions to control the front LEDs
Brightness 0 to 299 -> LEDs off
Brightness 300 to 699 -> LEDs half bright
Brightness 700 to 1000 -> LEDs full bright
Brightness=500
OffBrightness is the the value used for the âbacklight offâ state
OffBrightness=0
EyeboxOne driver
[EyeboxOne]
Select the output device to use [default: /dev/ttyS1]
#Device=/dev/cua01
Device=/dev/ttyS1
Set the display size [default: 20x4]
Size=20x4
Switch on the backlight? [default: yes]
Backlight=yes
Switch on the cursor? [default: no]
Cursor=no
Set the communication speed [default: 19200; legal: 1200, 2400, 9600, 19200]
Speed=19200
Enter Key is a \r character, so itâs hardcoded in the driver
LeftKey=D
RightKey=C
UpKey=A
DownKey=B
EscapeKey=P
You can find out which key of your display sends which
character by setting keypad_test_mode to yes and running
LCDd. LCDd will output all characters it receives.
Afterwards you can modify the settings above and set
keypad_set_mode to no again.
keypad_test_mode=no
g15 driver for Logitech G15 Keyboard LCDs
[g15]
Display size (currently unused)
size=20x5
glcdlib meta driver for graphical LCDs
[glcdlib]
mandatory:
which graphical display supported by graphlcd-base to use [default: image]
(see /etc/graphlcd.conf for possible drivers)
Driver=noritake800
no=use graphlcd bitmap fonts (they have only one size / font file)
yes=use fonts supported by FreeType2 (needs Freetype2 support in
libglcdprocdriver and its dependants)
UseFT2=yes
text resolution in fixed width characters [default: 16x4]
(if it wonât fit according to available physical pixel resolution
and the minimum available font face size in pixels, then
âDebugBorderâ will automatically be turned on)
TextResolution=20x4
path to font file to use
FontFile=/usr/share/fonts/corefonts/courbd.ttf
these only apply if UseFT2=yes:
character encoding to use
CharEncoding=iso8859-2
minimum size in pixels in which fonts should be rendered
MinFontFaceSize=7x12
optional:
Brightness=50 # Brightness (in %) if applicable
Contrast=50 # Contrast (in %) if applicable
Backlight=no # Backlight if applicable
UpsideDown=no # flip image upside down
Invert=no # invert light/dark pixels
ShowDebugFrame=no # turns on/off 1 pixel thick debugging
# border within the usable text area,
# for setting up TextResolution and
# MinFontFaceSize (if using FT2);
ShowBigBorder=no # border around the unused area
ShowThinBorder=yes # border around the unused area
PixelShiftX=0
PixelShiftY=2
Matrix Orbital GLK driver
[glk]
select the serial device to use [default: /dev/lcd]
Device=/dev/lcd
set the initial contrast value [default: 560; legal: 0 - 1000]
Contrast=560
set the serial port speed [default: 19200; legal: 9600, 19200, 38400]
Speed=19200
Hitachi HD44780 driver
[hd44780]
Select what type of connection. See documentation for types.
ConnectionType=i2c
Port where the LPT is. Usual value are: 0x278, 0x378 and 0x3BC
Port=0x27
Device of the serial interface [default: /dev/lcd]
Device=/dev/i2c-1
Bitrate of the serial port (0 for interface default)
Speed=0
You may also need to configure the keypad layout further on in this file.
Keypad=no
Set the initial contrast (bwctusb and lcd2usb) [default: 500; legal: 0 - 1000]
Contrast=0
Set brightness of the backlight (lcd2usb only) [default: 0; legal: 0 - 1000]
#Brightness=1000
#OffBrightness=0
If you have a switchable backlight.
Backlight=no
If you have the additional output port (âbargraphâ) and you want to
be able to control it with the lcdproc OUTPUT command
OutputPort=no
Specifies if the last line is pixel addressable (yes) or it controls an
underline effect (no). [default: yes; legal: yes, no]
#Lastline=yes
Specifies the size of the LCD.
In case of multiple combined displays, this should be the total size.
Size=16x2
i2c_line_RS=0x01
i2c_line_RW=0x02
i2c_line_EN=0x04
i2c_line_BL=0x08
i2c_line_D4=0x10
i2c_line_D5=0x20
i2c_line_D6=0x40
i2c_line_D7=0x80
For multiple combined displays: how many lines does each display have.
Vspan=2,2 means both displays have 2 lines.
#vspan=2,2
If you have an HD66712, a KS0073 or another âalmost HD44780-compatibleâ,
set this flag to get into extended mode (4-line linear).
#ExtendedMode=yes
In extended mode, on some controllers like the ST7036 (in 3 line mode)
the next line in DDRAM wonât start 0x20 higher. [default: 0x20]
#LineAddress=0x10
Character map to to map ISO-8859-1 to the LCDâs character set
[default: hd44780_default; legal: hd44780_default, hd44780_euro, ea_ks0073,
sed1278f_0b, hd44780_koi8_r, hd44780_cp1251, hd44780_8859_5, upd16314 ]
(hd44780_koi8_r, hd44780_cp1251, hd44780_8859_5 and upd16314 are possible if
compiled with additional charmaps)
CharMap=hd44780_default
If your display is slow and cannot keep up with the flow of data from
LCDd, garbage can appear on the LCDd. Set this delay factor to 2 or 4
to increase the delays. Default: 1.
#DelayMult=2
Some displays (e.g. vdr-wakeup) need a message from the driver to that it
is still alive. When set to a value bigger then null the character in the
upper left corner is updated every seconds. Default: 0.
#KeepAliveDisplay=0
If you experience occasional garbage on your display you can use this
option as workaround. If set to a value bigger than null it forces a
full screen refresh seconds. Default: 0.
#RefreshDisplay=5
You can reduce the inserted delays by setting this to false.
On fast PCs it is possible your LCD does not respond correctly.
Default: true.
DelayBus=true
If you have a keypad you can assign keystrings to the keys.
See documentation for used terms and how to wire it.
For example to give directly connected key 4 the string âEnterâ, use:
KeyDirect_4=Enter
For matrix keys use the X and Y coordinates of the key:
KeyMatrix_1_3=Enter
KeyMatrix_4_1=Enter
KeyMatrix_4_2=Up
KeyMatrix_4_3=Down
KeyMatrix_4_4=Escape
ICP A106 driver
[icp_a106]
Device=/dev/ttyS1
Code Mercenaries IO-Warrior driver
[IOWarrior]
display dimensions
Size=20x4
serial number. Must be exactly as listed by usbview
(if not given, the 1st IOWarrior found gets used)
#SerialNumber=00000674
#ExtendedMode=yes
#Lastline=yes
Soundgraph/Ahanix/Silverstone/Uneed/Accent iMON driver
[imon]
select the device to use
Device=/dev/lcd0
display dimensions
Size=16x2
Character map to to map ISO-8859-1 to the displays character set.
[default: none; legal: none, hd44780_euro, upd16314, hd44780_koi8_r,
hd44780_cp1251, hd44780_8859_5 ] (upd16314, hd44780_koi8_r,
hd44780_cp1251, hd44780_8859_5 are possible if compiled with additional
charmaps)
CharMap=hd44780_euro
Soundgraph iMON LCD
[imonlcd]
Specify which iMon protocol should be used
[legal: 0, 1; default: 0]
Choose 0 for 15c2:ffdc device,
Choose 1 for 15c2:0038 device
Protocol=0
Set the exit behavior [legal: 0-2; default: 1]
0 means leave shutdown message,
1 means show the big clock,
2 means blank device
#OnExit=2
Select the output device to use [default: /dev/lcd0]
Device=/dev/lcd0
Select the displays contrast [default: 200; legal: 0-1000]
Contrast=200
Specify the size of the display in pixels [default: 96x16]
#Size=96x16
Set the backlight state [default: on; legal: on, off]
#Backlight=on
Set the disc mode [legal: 0,1; default: 0]
0 => spin the âslimâ disc - two disc segments,
1 => their complement spinning;
#DiscMode=0
IrMan driver
[IrMan]
in case of trouble with IrMan, try the Lirc emulator for IrMan
Select the input device to use
#Device=/dev/irman
Select the configuration file to use
#Config=/etc/irman.cfg
IRtrans driver
[irtrans]
Does the device have a backlight? [default: no; legal: yes, no]
#Backlight=no
IRTrans device to connect to [default: localhost]
#Hostname=localhost
display dimensions
Size=16x2
Joystick driver
[joy]
Select the input device to use [default: /dev/js0]
Device=/dev/js0
set the axis map
Map_Axis1neg=Left
Map_Axis1pos=Right
Map_Axis2neg=Up
Map_Axis2pos=Down
set the button map
Map_Button1=Enter
Map_Button2=Escape
LB216 driver
[lb216]
Device=/dev/lcd
Set the initial brightness [default: 255; legal: 0 - 255]
Brightness=255
Set the communication speed [default: 9600; legal: 2400, 9600]
Speed=9600
Reboot=no
LCDM001 driver
[lcdm001]
Device=/dev/ttyS1
keypad settings
Keyname Function
Normal context Menu context
PauseKey Pause/Continue Enter/select
BackKey Back(Go to previous screen) Up/Left
ForwardKey Forward(Go to next screen) Down/Right
MainMenuKey Open main menu Exit/Cancel
PauseKey=LeftKey
BackKey=UpKey
ForwardKey=DownKey
MainMenuKey=RightKey
You can rearrange the settings here.
If your device is broken, have a look at server/drivers/lcdm001.h
HNE LCTerm driver
[lcterm]
Device=/dev/ttyS1
Size=16x2
LIRC input driver
[lirc]
Specify an alternative location of the lircrc file [default: ~/.lircrc]
#lircrc=/etc/lircrc.lcdproc
Must be the same as in your lircrc
#prog=lcdd
LIS MCE 2005 driver
[lis]
0-250 = 25%, 251-500 = 50%, 501-750 = 75%, 751-1000 = 100%
#Brightness=1000
Columns by lines [default: 20x2]
#Size=20x2
USB Vendor ID [default: 0x0403]
Change only if testing a compatible device.
#VendorID=0x0403
USB Product ID [default: 0x6001]
#ProductID=0x6001
##The driver for the VFD of the Medion MD8800 PC ##
[MD8800]
#Device=/dev/ttyS1
display size [default: 16x2]
#Size=16x2
Brightness=1000
OffBrightness=50
Futuba MDM166A Display
[mdm166a]
Show self-running clock after LCDd shutdown
Possible values: [default: no; legal: no, small, big]
Clock=big
Dim display, no dimming gives full brightness [default: no, legal: yes, no]
Dimming=no
Dim display in case LCDd is inactive [default: no, legal: yes, no]
OffDimming=yes
MSI MS-6931 driver for displays in 1HU servers
[ms6931]
Device=/dev/ttyS1
#Size=16x2
MTC-S16209x driver
[mtc_s16209x]
Device=/dev/lcd
Brightness=255
Reboot=no
Matrix Orbital driver
[MtxOrb]
Device=/dev/ttyS0
Size=20x4
Set the display type [default: lcd; legal: lcd, lkd, vfd, vkd]
Type=lkd
Set the initial contrast [default: 480]
NOTE: The driver will ignore this if the display
is a vfd or vkd as they donât have this feature
Contrast=480
Some old displays do not have an adjustable backlight but only can
switch the backlight on/off. If you experience randomly appearing block
characters, try setting this to false. [default: yes; legal: yes, no]
hasAdjustableBacklight=no
Brightness=1000
OffBrightness=0
Speed=19200
The following table translates from MtxOrb key letters to logical key names.
By default no keys are mapped, meaning the keypad is not used at all.
#KeyMap_A=Left
#KeyMap_B=Right
#KeyMap_C=Up
#KeyMap_D=Down
#KeyMap_E=Enter
#KeyMap_F=Escape
See the [menu] section for an explanation of the key mappings
keypad_test_mode=no
mx5000 driver for LCD display on the Logitech MX5000 keyboard
[mx5000]
Select the output device to use [default: /dev/hiddev0]
Device = /dev/hiddev0
Time to wait in ms after the refresh screen has been sent [default: 1000]
WaitAfterRefresh = 1000
Noritake VFD driver
[NoritakeVFD]
device where the VFD is. Usual values are /dev/ttyS0 and /dev/ttyS1
[default: /dev/lcd]
Device=/dev/ttyS0
Size=20x4
Brightness=1000
OffBrightness=50
set the serial port speed [default: 9600, legal: 1200, 2400, 9600, 19200, 115200]
Speed=9600
Set serial data parity [default: 0; legal: 0-2 ]
Meaning: 0(=none), 1(=odd), 2(=even)
Parity=0
re-initialize the VFD [default: no; legal: yes, no]
Reboot=no
[picolcd]
KeyTimeout is the time in ms that LCDd spends waiting for a key press before
cycling through other duties. Higher values make LCDd use less CPU time and
make key presses more detectable. Lower values make LCDd more responsive
but a little prone to missing key presses. 500 (.5 second) is the default
and a balanced value. [default: 500; legal: 0 - 1000]
KeyTimeout=500
Sets the initial state of the backlight upon start-up.
#Backlight=on
Set the initial brightness [default: 1000; legal: 0 - 1000]. Works only
with the 20x4 device
Brightness=1000
Set the brightness while the backlight is âoffâ [default: 0; legal: 0 - 1000].
Works only with the 20x4 device.
#OffBrightness=0
Set the initial contrast [default: 1000; legal: 0 - 1000]
Contrast=1000
Light the keys? [default: on; legal: on, off]
Keylights=on
If Keylights is on, the you can unlight specific keys below:
Key0 is the directional pad. Key1 - Key5 correspond to the F1 - F5 keys.
There is no LED for the +/- keys. This is a handy way to indicate to users
which keys are disabled. [default: on; legal: on, off]
Key0Light=on
Key1Light=on
Key2Light=on
Key3Light=on
Key4Light=on
Key5Light=on
Host name or IP address of the LIRC instance that is to receive IR codes
If not set, or set to an empty value, IR support is disabled.
#LircHost=127.0.0.1
UDP port on which LIRC is listening [default: 8765; legal: 1 - 65535]
LircPort=8765
Threshold in jiffies of synthesized gap that triggers flushing the IR data
to lirc [default: 100 ; max: 32767 ]
100 means 6.1ms. legal: 16 - 32767; Use 0 to disable.
LircFlushThreshold=100
Pyramid LCD driver
[pyramid]
device to connect to [default: /dev/lcd]
Device=/dev/ttyUSB0
Seiko Epson 1330 driver
[sed1330]
Port where the LPT is. Common values are 0x278, 0x378 and 0x3BC
Port=0x378
Type of LCD module (legal: G321D, G121C, G242C, G191D, G2446, SP14Q002)
Note: Currently only tested with G321D & SP14Q002.
Type=G321D
Width x Height of a character cell in pixels [legal: 6x7 - 8x16; default: 6x10]
CellSize=6x10
Select what type of connection [legal: classic, bitshaker; default: classic]
ConnectionType=classic
Seiko Epson 1520 driver
[sed1520]
Port where the LPT is. Usual values are 0x278, 0x378 and 0x3BC
Port=0x378
Select the interface type (wiring) for the display. Supported values are
68 for 68-style connection (RESET level high) and 80 for 80-style connection
(RESET level low). [legal: 68, 80; default: 80]
InterfaceType=68
On fast machines it may be necessary to slow down transfer to the display.
If this value is set to zero, delay is disabled. Any value greater than
zero slows down each write by one microsecond. [legal: 0-1000; default: 1]
DelayMult=0
serial POS display driver
[serialPOS]
Device to use in serial mode [default: /dev/lcd]
Device=/dev/lcd
Specifies the size of the display in characters. [default: 16x2]
Size=16x2
Set the communication protocol to use with the POS display.
[default: AEDEX; legal: IEE, Epson, Emax, IBM, LogicControls, Ultimate]
Type=AEDEX
communication baud rate with the display [default: 9600; legal: 1200, 2400,
19200, 115200]
Speed=9600
Serial VFD driver
Drives various (see below) serial 5x7dot VFDâs.
[serialVFD]
Specifies the displaytype.[default: 0]
0 NEC (FIPC8367 based) VFDs.
1 KD Rev 2.1.
2 Noritake VFDs (*).
3 Futaba VFDs
4 IEE S03601-95B
5 IEE S03601-96-080 (*)
6 Futaba NA202SD08FA (allmost IEE compatible)
7 Samsung 20S207DA4 and 20S207DA6
8 Nixdorf BA6x / VT100
(* most should work, not tested yet.)
Type=0
ânoâ if display connected serial, âyesâ if connected parallel. [default: no]
I.e. serial by default
use_parallel=no
Number of Custom-Characters. default is display type dependent
#Custom-Characters=0
Portaddress where the LPT is. Used in parallel mode only. Usual values are
0x278, 0x378 and 0x3BC.
Port=0x378
Set parallel port timing delay (us). Used in parallel mode only.
[default: 2; legal: 0 - 255]
#PortWait=2
Device to use in serial mode. Usual values are /dev/ttyS0 and /dev/ttyS1
Device=/dev/ttyS1
Specifies the size of the VFD.
Size=20x2
(4 steps 0-250, 251-500, 501-750, 751-1000)
Brightness=1000
OffBrightness=0
set the serial port speed [default: 9600; legal: 1200, 2400, 9600, 19200, 115200]
Speed=9600
enable ISO 8859 1 compatibility [default: yes; legal: yes, no]
#ISO_8859_1=yes
shuttleVFD driver
[shuttleVFD]
No options
stv5730 driver
[stv5730]
Port the device is connected to [default: 0x378]
Port=0x378
[SureElec]
Port the device is connected to (by default first USB serial port)
Device=/dev/ttyUSB0
Edition level of the device (can be 1, 2 or 3) [default: 2]
#Edition=1
set display size
Note: The size can be obtained directly from device for edition 2 & 3.
#Size=16x2
Set the initial contrast [default: 480; legal: 0 - 1000]
#Contrast=200
Set the initial brightness [default: 480; legal: 1 - 1000]
#Brightness=480
Set the initial off-brightness [default: 100; legal: 1 - 1000]
#OffBrightness=100
SVGAlib driver
[svga]
svgalib mode to use [default: G320x240x256 ]
legal values are supported svgalib modes
#Mode=G640x480x256
set display size [default: 20x4]
Size=20x4
Set the initial contrast [default: 500; legal: 0 - 1000]
Can be set but does not change anything internally
Contrast=500
Set the initial brightness [default: 1000; legal: 1 - 1000]
Brightness=1000
Set the initial off-brightness [default: 500; legal: 1 - 1000]
OffBrightness=500
Text driver
[text]
Size=20x4
Toshiba T6963 driver
[t6963]
set display size in pixels [default: 128x64]
Size=128x64
port to use [default: 0x378; legal: 0x200 - 0x400]
Port=0x378
Use LPT port in bi-directional mode. This should work on most LPT port and
is required for proper timing! [default: yes; legal: yes, no]
#bidirectional=yes
Insert additional delays into reads / writes. [default: no; legal: yes, no]
#delayBus=no
Clear graphic memory on start-up. [default: no; legal: yes, no]
#ClearGraphic=no
Tyan Barebones LCD driver (GS10 & GS12 series)
[tyan]
Device=/dev/lcd
Set the communication speed [default: 9600; legal: 4800, 9600]
Speed=9600
set display size [default: 16x2]
Size=16x2
ELV ula200 driver
[ula200]
Size=20x4
If you have a non standard keypad you can associate any keystrings to keys.
There are 6 input key in the CwLnx hardware that generate characters
from âAâ to âFâ.
The following it the built-in default mapping hardcoded in the driver.
standard keypad.
KeyMap_A=Up
KeyMap_B=Down
KeyMap_C=Left
KeyMap_D=Right
KeyMap_E=Enter
KeyMap_F=Escape
Wirz SLI LCD driver
[sli]
Device=/dev/lcd
Set the communication speed [default: 19200; legal: 1200, 2400, 9600, 19200,
38400, 57600, 115200]
Speed=19200
OnScreen Display using libxosd
[xosd]
Size=20x4
Offset in pixels from the top-left corner of the monitor [default: 0x0]
Offset=200x200
X font to use, in XLFD format, as given by âxfontselâ
Font=--terminus--r----320-----
EOF
[/code][/spoiler]
sudo nano /etc/init.d/mpdlcd
[spoiler][code]
#! /bin/sh
case â$1â in
start)
/usr/local/bin/mpdlcd --no-syslog &
stop)
killall mpdlcd
echo âUsage: /etc/init.d/mpdlcd {start|stop}â
exit 1
esac
exit 0
[/code][/spoiler]
sudo chmod a+x /etc/init.d/mpdlcd
sudo update-rc.d mpdlcd defaults
sudo update-rc.d LCDd defaults
sudo shutdown -r now
