[GUIDE] Waveshare 11.9"/7.9" DSI LCD Display Configuration for Volumio 4
Waveshare DSI display configuration guide for Volumio OS
KNOWN ISSUE: Intermittent dark display on cold boot (Raspberry Pi 4)
Waveshare 7.9" and 11.9" DSI displays may fail to initialize on cold boot while diagnostics report success (DSI connected, backlight on, xrandr shows output). Confirmed on Pi 4 revisions 1.2, 1.4, and 1.5 running kernel 6.x.
Cause: The Waveshare ws_touchscreen driver attempts I2C communication with the panel controller (address 0x45) without initialization delay or retry logic. On cold boot, the panel controller may not be ready, resulting in:
ws_touchscreen 10-0045: I2C write failed: -5
Behavior pattern:
  • Short power cycle (under 10 seconds): More likely to succeed
  • Long power down (overnight): More likely to fail
  • Multiple reboots: May eventually succeed
This is a Waveshare driver defect, not a configuration problem. The configurations in this guide are correct. Contact Waveshare support and reference this error if you experience this issue.
Supported hardware
Raspberry Pi models
  • Raspberry Pi 4B+ - Tested with all scenarios
  • Raspberry Pi 5 - Tested with all scenarios
Waveshare DSI displays
  • 11.9 inch DSI LCD - Native resolution 320x1480 (portrait)
  • 7.9 inch DSI LCD - Native resolution 400x1280 (portrait)
Operating system
  • Volumio OS (Debian Bookworm-based)
Display-specific parameters reference
All configurations require display-specific parameters. Use this table to determine correct values for your display.
Parameter table by display size
Parameter 11.9 inch display 7.9 inch display
Native resolution 320x1480 (portrait) 400x1280 (portrait)
Rotated resolution 1480x320 (landscape) 1280x400 (landscape)
dtoverlay line dtoverlay=vc4-kms-dsi-waveshare-panel,11_9_inch,rotation=270 dtoverlay=vc4-kms-dsi-waveshare-panel,7_9_inch,rotation=270
video= parameter video=DSI-1:320x1480@60,rotate=270 video=DSI-1:400x1280e,rotate=270
Expected fbset output mode "1480x320" mode "1280x400"
Important notes:
  • Both displays use rotation=270 in dtoverlay for landscape orientation
  • 7.9 inch display requires “e” flag in video= parameter: 400x1280e
  • 11.9 inch display does NOT use “e” flag: 320x1480@60
Complete example configurations
This section provides complete, ready-to-use configuration files for common setups. Choose the example matching your hardware and copy the entire configuration.
Example 1: Raspberry Pi 4B+ with 11.9 inch display (Scenario 1)
Complete /boot/userconfig.txt:
[pi4]
dtoverlay=vc4-kms-v3d-pi4
hdmi_force_hotplug=0
disable_overscan=1
dtparam=audio=off
[all]
Add to end of /boot/cmdline.txt:
Expected fbset output:
mode "1480x320"
Example 2: Raspberry Pi 5 with 11.9 inch display (Scenario 1)
hdmi_drive=2
disable_overscan=1
mode "1480x320"
Example 3: Raspberry Pi 4B+ with 7.9 inch display (Scenario 1)
[pi4]
disable_overscan=1
dtparam=audio=off
[all]
Note: The “e” flag is required for 7.9 inch display.
mode "1280x400"
Example 4: Raspberry Pi 5 with 7.9 inch display (Scenario 1)
hdmi_drive=2
disable_overscan=1
mode "1280x400"
Example 5: Raspberry Pi 4B+ with 11.9 inch + HDMI port 0 audio (Scenario 3)
[pi4]
hdmi_force_hotplug:0=1
hdmi_drive:0=2
hdmi_ignore_edid:0=0xa5000080
disable_overscan=1
[all]
video=DSI-1:320x1480@60,rotate=270 video=HDMI-A-1:d
Expected result: Display on DSI, audio from HDMI port 0
Example 6: Raspberry Pi 5 with 7.9 inch + both HDMI ports audio (Scenario 5)
hdmi_force_hotplug:1=1
hdmi_drive:0=2
hdmi_drive:1=2
hdmi_ignore_edid:1=0xa5000080
disable_overscan=1
video=DSI-1:400x1280e,rotate=270 video=HDMI-A-1:d video=HDMI-A-2:d
Expected result: Display on DSI, audio from both HDMI ports (Volumio uses one)
Physical orientation (270-degree rotation)
Raspberry Pi 4B+ and Pi 5 mounting (when viewing from screen side):
  • Bottom edge: USB-C power port, HDMI ports
  • Left edge: USB ports, Ethernet/LAN port
  • Top edge: GPIO header
  • Right edge: SD card slot (micro SD on Pi 4B+, full size SD on Pi 5)
Note: When mounting the Pi from behind (looking at the back of the display), left and right edges are reversed from this description.
Display orientation with 270-degree rotation:
  • Display top edge: Aligned with GPIO header (Pi top edge)
  • Display bottom edge: Aligned with USB-C/HDMI ports (Pi bottom edge)
Configuration scenarios overview
Scenario Audio output HDMI port 0 HDMI port 1 Use case
1 None/Disabled Disabled Disabled Minimal setup, no audio
2 I2S DAC Disabled Disabled High-quality audio via DAC
3 HDMI audio Audio only Disabled Soundbar/AVR on HDMI 0
4 HDMI audio Disabled Audio only Soundbar/AVR on HDMI 1
5 HDMI audio Audio only Audio only Dual audio output capability
Common base configuration
Raspberry Pi 4B+
All scenarios share this base configuration in /boot/userconfig.txt:
[pi4]
<INSERT DISPLAY-SPECIFIC dtoverlay LINE FROM TABLE>
disable_overscan=1
Add scenario-specific parameters below this base.
Raspberry Pi 5
All scenarios use this simplified configuration in /boot/userconfig.txt:
hdmi_drive=2
disable_overscan=1
Key differences for Pi 5:
  • No section markers ([pi4], [all]) needed
  • No vc4-kms-v3d overlay (handled automatically by volumioconfig.txt)
  • Simplified HDMI configuration
cmdline.txt configuration
For all scenarios on both Pi 4B+ and Pi 5:
Add the display-specific video= parameter from the table to the END of /boot/cmdline.txt:
<INSERT DISPLAY-SPECIFIC video= PARAMETER FROM TABLE>
Space-separate from previous parameters.
Example for 11.9 inch display:
... use_kmsg=no video=DSI-1:320x1480@60,rotate=270
Example for 7.9 inch display:
... use_kmsg=no video=DSI-1:400x1280e,rotate=270
Scenario 1: DSI only (no audio)
Purpose
Minimal configuration for display only, all audio outputs disabled.
Configuration
Raspberry Pi 4B+
[pi4]
disable_overscan=1
dtparam=audio=off
[all]
Raspberry Pi 5
hdmi_drive=2
disable_overscan=1
Both Pi 4B+ and Pi 5
/boot/cmdline.txt:
  • Add to the END of the existing single line: <INSERT DISPLAY-SPECIFIC video= PARAMETER FROM TABLE>
  • Space-separate from previous parameters
Expected results
  • fbset shows display-specific resolution (see parameter table)
  • No HDMI interference
  • Plymouth displays correctly on DSI with landscape rotation
  • Console properly rotated to landscape
  • No audio outputs active
Scenario 2: DSI + I2S DAC
Purpose
High-quality audio through external I2S DAC while maintaining DSI display.
Configuration
Raspberry Pi 4B+
[pi4]
disable_overscan=1
dtparam=audio=off
[all]
Raspberry Pi 5
hdmi_drive=2
disable_overscan=1
/boot/cmdline.txt:
DAC Configuration via Volumio UI:
Do NOT add DAC overlays to userconfig.txt. Configure your I2S DAC through Volumio’s web interface:
  1. Open Volumio web UI (http://volumio.local)
  2. Navigate to: Settings → Playback Options
  3. Under Output Device, select your I2S DAC from the dropdown
  4. Click Save
  5. Volumio will automatically add the correct DAC overlay to /boot/config.txt
  6. Reboot when prompted
Important: Volumio manages DAC configuration in /boot/config.txt (system file). User modifications should only go in /boot/userconfig.txt. The two files work together - config.txt is managed by Volumio, userconfig.txt is for user customizations like display settings.
Expected results
  • I2S DAC active for audio output (configured via Volumio UI)
  • HDMI audio disabled
Scenario 3: DSI + HDMI port 0 audio
Purpose
Extract audio from HDMI port 0 (closer to USB-C power) while disabling video output.
Configuration
Raspberry Pi 4B+
[pi4]
hdmi_drive:0=2
disable_overscan=1
[all]
Raspberry Pi 5
hdmi_drive:0=2
disable_overscan=1
/boot/cmdline.txt:
  • Add to the END of the existing single line: <INSERT DISPLAY-SPECIFIC video= PARAMETER FROM TABLE> video=HDMI-A-1:d
... use_kmsg=no video=DSI-1:320x1480@60,rotate=270 video=HDMI-A-1:d
Expected results
  • HDMI-A-1 video disabled but audio active
  • HDMI audio available to soundbar/AVR connected to port 0
Scenario 4: DSI + HDMI port 1 audio
Purpose
Extract audio from HDMI port 1 (farther from USB-C power) while disabling video output.
Configuration
Raspberry Pi 4B+
[pi4]
hdmi_drive:1=2
disable_overscan=1
[all]
Raspberry Pi 5
hdmi_drive:1=2
disable_overscan=1
/boot/cmdline.txt:
  • Add to the END of the existing single line: <INSERT DISPLAY-SPECIFIC video= PARAMETER FROM TABLE> video=HDMI-A-2:d
... use_kmsg=no video=DSI-1:320x1480@60,rotate=270 video=HDMI-A-2:d
Expected results
  • HDMI-A-2 video disabled but audio active
  • HDMI audio available to soundbar/AVR connected to port 1
Scenario 5: DSI + both HDMI ports audio
Purpose
Extract audio from both HDMI ports simultaneously while disabling video output.
Configuration
Raspberry Pi 4B+
[pi4]
hdmi_drive:0=2
hdmi_drive:1=2
disable_overscan=1
[all]
Raspberry Pi 5
hdmi_drive:0=2
hdmi_drive:1=2
disable_overscan=1
/boot/cmdline.txt:
  • Add to the END of the existing single line: <INSERT DISPLAY-SPECIFIC video= PARAMETER FROM TABLE> video=HDMI-A-1:d video=HDMI-A-2:d
... use_kmsg=no video=DSI-1:320x1480@60,rotate=270 video=HDMI-A-1:d video=HDMI-A-2:d
Expected results
  • Both HDMI video outputs disabled but audio active on both ports
  • HDMI audio available on both ports (Volumio will default to one)
Parameter reference
Display parameters
Parameter Function
dtoverlay=vc4-kms-v3d-pi4 Enables VC4 KMS display driver for Pi 4 (Pi 4B+ only)
dtoverlay=vc4-kms-dsi-waveshare-panel,<size>,rotation=270 Loads Waveshare DSI panel driver with 270-degree rotation
video=DSI-1:<resolution>,rotate=270 Kernel-level framebuffer rotation for console
disable_overscan=1 Prevents display area reduction (no black borders)
HDMI audio parameters
Parameter Function
hdmi_force_hotplug:N=1 Keeps HDMI port N active (0=first port, 1=second port)
hdmi_drive:N=2 Forces HDMI audio mode (not DVI) on port N
hdmi_ignore_edid:N=0xa5000080 Ignores display detection on port N (audio-only mode)
video=HDMI-A-N:d Kernel-level disable of HDMI-A-N video output
Audio parameters
Parameter Function
dtparam=audio=off Disables onboard 3.5mm audio jack (Pi 4B+ only)
dtoverlay=<dac-name> Loads specific I2S DAC driver overlay
Verification commands
After rebooting with new configuration, verify setup with these commands:
Check framebuffer resolution
fbset
Expected output for 11.9 inch display:
mode "1480x320"
    geometry 1480 320 1480 320 16
Expected output for 7.9 inch display:
mode "1280x400"
    geometry 1280 400 1280 400 16
Check kernel command line
cat /proc/cmdline | grep video
Expected output for 11.9 inch (Scenario 3):
... video=DSI-1:320x1480@60,rotate=270 video=HDMI-A-1:d
Expected output for 7.9 inch (Scenario 3):
... video=DSI-1:400x1280e,rotate=270 video=HDMI-A-1:d
Check DSI display status
cat /sys/class/drm/card1-DSI-1/modes
cat /sys/class/drm/card1-DSI-1/status
Expected output for 11.9 inch:
320x1480
connected
Expected output for 7.9 inch:
400x1280
connected
Check HDMI configuration
vcgencmd get_config int | grep hdmi
Expected output (Scenario 3):
hdmi_drive:0=2
Check display devices
ls /sys/class/drm/
Expected output:
card0  card0-HDMI-A-1  card0-HDMI-A-2  card1  card1-DSI-1  ...
Troubleshooting
Issue: Framebuffer shows wrong resolution
Symptoms:
fbset
mode "320x480"  # Wrong for 11.9 inch
mode "400x480"  # Wrong for 7.9 inch
Causes:
  1. HDMI parameters injected by firmware before DSI configuration
  2. Conflicting video= parameters in cmdline.txt
  3. Missing video=DSI-1 rotation parameter
  4. Wrong display-specific parameters used
Solution:
  1. Verify hdmi_force_hotplug=0 in userconfig.txt (or proper port-specific settings)
  2. Check /proc/cmdline for unexpected video=HDMI parameters
  3. Ensure correct display-specific video= parameter from table is in cmdline.txt
  4. Verify video=DSI-1 parameter appears BEFORE any HDMI parameters
  5. Double-check you’re using parameters for the correct display size
Issue: Console in portrait mode despite rotation
Symptoms:
  • Plymouth displays correctly rotated
  • Console text appears in portrait orientation
  • Login prompt sideways
Solution:
  • Add display-specific video=DSI-1:... parameter to cmdline.txt
  • This parameter rotates the framebuffer/console layer
  • dtoverlay rotation alone only affects panel hardware, not console
  • Verify you’re using the correct video= parameter for your display size
Issue: 7.9 inch display not working
Symptoms:
  • Black screen or no output
  • fbset shows wrong resolution
Solution:
  • Verify video= parameter includes “e” flag: video=DSI-1:400x1280e,rotate=270
  • The “e” flag is required for 7.9 inch display
Issue: HDMI audio not working
Symptoms:
  • No audio output from HDMI-connected device
  • Volumio doesn’t list HDMI as audio output option
Solution:
  1. Verify hdmi_drive:N=2 is set (forces audio mode)
  2. Check HDMI cable supports audio (not all do)
  3. Verify soundbar/AVR is set to correct HDMI input
  4. Check Volumio audio output settings in web interface
Issue: Plymouth not displaying during boot
Symptoms:
  • Black screen during boot
  • Boot messages appear but no Plymouth splash
Solution:
  1. Verify DSI display is detected: cat /sys/class/drm/card1-DSI-1/status
  2. Check Plymouth is enabled: plymouth --ping
  3. Review initramfs Plymouth script: /scripts/init-premount/plymouth
  4. Check kernel messages: dmesg | grep -i plymouth
Issue: Display corruption or multiple segments
Symptoms:
  • Screen shows multiple copies of content
  • Distorted or rotated incorrectly
Solution:
  1. Ensure dtoverlay rotation matches video= rotation (both 270 degrees)
  2. Never use different rotation values in dtoverlay vs video= parameter
  3. Check for duplicate rotation specifications
  4. Verify using correct display-specific parameters
Notes and best practices
Important warnings
  1. Never edit /boot/config.txt directly - Always use /boot/userconfig.txt for custom settings
  2. cmdline.txt is a single line - All parameters must be on one line, space-separated
  3. Rotation values must match - dtoverlay rotation and video= rotation must be identical
  4. DSI parameter goes first - Place video=DSI-1 before any HDMI parameters in cmdline.txt
  5. Use correct display parameters - 11.9 inch and 7.9 inch require different parameters
  6. 7.9 inch needs “e” flag - video= parameter must include “e”: 400x1280e
  7. Firmware interference - hdmi_force_hotplug triggers automatic HDMI detection
  8. Configure DACs via Volumio UI - Never manually add DAC overlays to userconfig.txt; use Settings → Playback Options instead
File preservation
These files are preserved during Volumio updates:
  • /boot/userconfig.txt - User configuration for display and custom hardware (safe to edit)
  • /boot/cmdline.txt - Kernel parameters (safe to edit)
These files are managed by Volumio:
  • /boot/config.txt - System configuration managed by Volumio (do not edit directly)
  • /boot/volumioconfig.txt - Volumio base config (do not edit)
Important distinction:
  • /boot/config.txt - Volumio writes system settings here (DAC configuration, base hardware settings)
  • /boot/userconfig.txt - User adds custom settings here (display configuration, additional hardware)
  • Both files are processed together at boot
  • Settings in userconfig.txt supplement (not replace) config.txt
  • Never manually add DAC overlays to userconfig.txt - use Volumio UI instead
Configuration testing workflow
  1. Identify your display size (11.9 inch or 7.9 inch)
  2. Reference the parameter table for display-specific values
  3. Make changes to configuration files using correct parameters
  4. Verify syntax (no typos, proper spacing)
  5. Reboot system
  6. Run verification commands
  7. Check Plymouth during boot
  8. Verify console rotation
  9. Test audio output if configured
  10. Document working configuration
Rotation angles reference
Rotation Native portrait Landscape result Display top edge aligns with
0 Native portrait Portrait mode N/A - portrait mode
90 Native portrait Landscape SD card slot (Pi right edge)
180 Native portrait Portrait upside down N/A - portrait upside down
270 Native portrait Landscape GPIO header (Pi top edge)
This guide uses 270-degree rotation for landscape display with GPIO header at top.
Why both dtoverlay and video= rotation?
  • dtoverlay rotation: Rotates panel at hardware/driver level
  • video= rotation: Rotates framebuffer/console layer at kernel level
  • Both required: Panel needs hardware rotation, console needs framebuffer rotation
  • Values must match: Using different rotation values causes display corruption
Document information
  • Version: 2.3
  • Date: 2025-12-14
  • Hardware: Raspberry Pi 4B+ and Raspberry Pi 5
  • Displays: Waveshare 11.9" DSI LCD (320x1480), Waveshare 7.9" DSI LCD (400x1280)
  • OS: Volumio (Debian Bookworm-based)
  • Author: Technical documentation for Volumio DSI display configuration
  • Testing status: All scenarios tested on Pi 4B+ and Pi 5 with 11.9" display; 7.9" parameters verified
  • Update notes:
    • Version 2.0 - Restructured for equal treatment of both display sizes
    • Version 2.1 - Corrected Scenario 2: DAC configuration via Volumio UI, not userconfig.txt
    • Version 2.2 - Added complete example configurations for all Pi/display combinations
    • Version 2.3 - Added known issue notice for Waveshare I2C timing bug; removed duplicate section
References
In addition to the 2 displays mentioned, I use a 8.8" 480x1920 Waveshare DSI touchscreen on a Pi5. These are the lines I run to get my screen working:
userconfig.txt:
#DSI1 Use
dtoverlay=vc4-kms-dsi-waveshare-panel,8_8_inch,rotation=90
hdmi_drive=2
disable_overscan=1
cmdline.txt:
video=DSI-1:480x1920@60,rotate=90
A gotcha I ran into was that my previous config had framebuffer set for width and height in userconfig and those lines caused the screen to have a triplicated garbled output. Removing those lines fixed it.
I’m beginning to think that there is some kind of incompatibility with my RPi 4 1.5 and WS DSI 11.9" display. It works flawlessly with Volumio 3, but with Volumio 4 there are strange problems I can’t solve.
When I install Volumio 4 from the start, with a “cold” system, the display never works. Since 4.062 at least there are no errors in the logs, but it stays black. At least for some while. At the 5th or 8th reboot it starts working.
If I boot with Volumio 3 or a standard graphic distribution (where the display always works fine) and then boot Volumio 4, the display always works. Again no errors in logs. But turning the system off by night means it won’t work when turning it on in the morning…
It looks like there is some kind of initialization or warm-up that is not being applied. But I really don’t know where to look.
Nobody has ever seen something like this?
I remember there was some incompatibility between this RPi 4 v1.5 and some DAC (PiFi perhaps?). Maybe I have to change this RPI…
Regards.
Ps. I started working on this with WaveShare but then Chinese New Year arrived and everything stopped…
Have you entered the specific line in userconfig.txt for your specific Waveshare screen?
From a fresh install and cold boot, without that line in that file, the screen will not initialize. So from a fresh install, with the screen not initialized, you must ssh in and add the appropriate line, then reboot for the screen to work.
Yes, I followed the guide step by step. At least twice. The Volumio 4 installation I have that works (after V3 or Raspbian or… initializing) curiously has this line:
instead of the
of the guide. But I changed cmdline.txt and userconfig.txt according to the guide. Results are worse in my case: only when initializing with a graphic “working” distro or after several reboots, the display starts working but only with the dtoverlay without the “-pi4”.
This is what I have and the results of fbtest that, by the way, are NOT the same as the shown in the OP:
volumio@volumio:~$ cat /boot/cmdline.txt
splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=serial0,115200 console=tty1 imgpart=UUID=78d948c3-935b-4358-b7df-c382779bbef9 imgfile=/volumio_current.sqsh bootpart=UUID=A1E8-5028 datapart=UUID=60f254d7-c70a-4b55-956c-3df3766a56af uuidconfig=cmdline.txt pcie_aspm=off pci=pcie_bus_safe rootwait bootdelay=7 logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0 nodebug use_kmsg=no video=DSI-1:320x1480@60,rotate=270
volumio@volumio:~$ cat /boot/userconfig.txt
disable_overscan=1
dtparam=audio=off
display_lcd_rotate=3
display_hdmi_rotate=3
volumio@volumio:~$ fbtest
/dev/fb0: res 320x1480, virtual 320x1480, line_len 640
In the meanwhile, Volumio 3 works flawlessly…
Best Regards
Just a quick update on my side.
Now I have a Volumio 4 installation that works always. I really don’t know why it does and why others don’t. I created a Volumio 4 microSD with latest release and just copied the .txt files from my (working) microSD. It did not work. I updated my working installation to latest release. It still works.
If anybody is suffering this same problem just send me a message and I’ll try to put an image of the microSD card somewhere. The biggest problem is that I used a 32GB card and I don’t know how to reduce the size :pensive:.
Best regards.
How did you get a working version? I have the same problem with a 7.9 inch Display. OS ist Volumio 4, latest version. It runs on a RPI4. I’ve no problems with Volumio 3, only with V4.
I wish I knew :pensive:. I just kept trying until I got a working installation that could initialize the display without the need of a previous graphic distro booting. I really don’t know what makes it work: I’ve tried to copy the /boot/*.txt files to a new instalaltion and it doesn’t “cold” boot. It works but after the display has been initialized.
I was in contact with WaveShare and exchanged some messages with them, but they said that they had to prepare a system and there was the Chines New Year and… They disappeared and never came back, and they won’t even answer my mails.
I don’t know if my working image could help you. I understand that your 7.9" display and mine share the same controller, but you would need to change the “dtoverlay” line. This is all I added to my userconfig.txt file:
disable_hdmi=1
dtoverlay=vc4-kms-v3d,nohdmi
max_framebuffers=2
In this last line you should change 11_9_inch for 7_9_inch (I suppose, not sure if this is the correct parameter).
Hope it helps. Regards
Angel
Ps. As I said before, if anybody wants my “working” image I could try to put it somewhere, but it’s a 21GB image (my 32G card) and there is no guarantee it works anywhere else…
Hey @aluisperezh, @Mustang65,
The guide exists precisely to avoid these situations. It was written with extensive testing and clear, copy-paste-ready examples for a reason.
@aluisperezh - Your configuration does not match the guide. Specifically:
  1. Missing section markers. The guide explicitly shows [pi4] before the Pi4 overlays and [all] at the end. Your userconfig.txt lacks both. Without [pi4], the firmware may not process those overlays correctly for your board.
  2. Extra parameters not in the guide. The display_lcd_rotate=3 and display_hdmi_rotate=3 come from Touch Display plugin. These are legacy rotation parameters and are NOT part of the guide.
  3. Your fbtest shows res 320x1480 - portrait mode. The guide states expected output is mode "1480x320" - landscape. This confirms rotation is not working, likely due to the above issues.
@Mustang65 - The “advice” you received contains parameters that do not exist anywhere in the guide: disable_hdmi=1, dtoverlay=vc4-kms-v3d,nohdmi, max_framebuffers=2. Following this will create new problems, not solve existing ones.
Please start fresh. Use the exact example configurations from the guide - they are complete and tested. Example 1 or Example 3 for Pi4 with 11.9 inch, Example 3 or 4 adapted for 7.9 inch.
Hi Nerd,
Thanks for your reply. I did exactly as described in the instructions. Several times. I installed Volumio (4.071 from 11/17/2025) from scratch, entered the changes in userconfig.txt and cmdline.txt via copy/paste, then rebooted and started the system via the Volumio interface. The screen remains dark, no matter how many times I do this. When I install Volumio 3 OS (3.832), the display starts up as intended and works.
Unfortunately, I don’t know what else to do and am considering using Volumio 3 OS, as it seems to work there.
My setup:
Raspberry Pi4 2GB
Innomaker DAC Pro Hat (Allo Katana)
Waveshare 7.9 DSI Display
Power supply 5V 4.1A USB C
Best regards
Translated with DeepL.com (free version)
Hey @Mustang65,
Thank you for the additional details. The hardware setup is clear, but to investigate why Volumio 4 behaves differently from Volumio 3, diagnostic data is required.
Please provide:
  1. Log link from http://<volumio_IP>/dev - paste the URL it generates after submitting
  2. Actual file contents - SSH into the device and run:
  1. Verification command outputs:
fbset
ls /sys/class/drm/
“I followed the guide exactly” and actually following the guide exactly are often two different things - the previous user also believed they followed it correctly but had missing section markers and extra parameters. The verification outputs will confirm whether the configuration was applied as intended.
The fact that Volumio 3 works and Volumio 4 does not suggests either a configuration difference or a kernel/driver behavior change between versions. The logs and outputs above will help identify which.
Hi @nerd
I did it exactly, including the section markers. I copy/pasted your codes like provided.
Here are my data from ssh:
volumio@volumio2:~$ cat /boot/userconfig.txt
[pi4]
disable_overscan=1
dtparam=audio=off
[all]
volumio@volumio2:~$
/boot/cmdline.txt
volumio@volumio2:~$ cat /boot/cmdline.txt
splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=serial0,115200 console=tty1 imgpart=UUID=2fcd4aa9-19da-4188-a556-3009b8a5e64a imgfile=/volumio_current.sqsh bootpart=UUID=DFF5-D140 datapart=UUID=08d6ed05-4edb-44af-8ed0-2ea18b54c960 uuidconfig=cmdline.txt pcie_aspm=off pci=pcie_bus_safe rootwait bootdelay=7 logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0 nodebug use_kmsg=no video=DSI-1:400x1280e,rotate=270
fbset…
volumio@volumio2:~$ fbset
ls /sys/class/drm/
mode "400x1280"
    geometry 400 1280 400 1280 16
    timings 0 0 0 0 0 0 0
    rgba 5/11,6/5,5/0,0/0
endmode
coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_hdmi=0  numa=fake=1 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:F6:56:9D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyS0,115200 console=tty1 imgpart=UUID=2fcd4aa9-19da-4188-a556-3009b8a5e64a imgfile=/volumio_current.sqsh bootpart=UUID=DFF5-D140 datapart=UUID=08d6ed05-4edb-44af-8ed0-2ea18b54c960 uuidconfig=cmdline.txt pcie_aspm=off pci=pcie_bus_safe rootwait bootdelay=7 logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0 nodebug use_kmsg=no video=DSI-1:400x1280e,rotate=270
connected
card0  card1-DSI-1     card1-HDMI-A-2     renderD128
card1  card1-HDMI-A-1  card1-Writeback-1  version
The Link from log/bug report:
http://logs.volumio.org/volumio/6Q8Ypt3.html
I hope you can see any problem. When you need additional information, let me know!
Best regards
I already stated all this. And I think I said I had tried your standard configuration and it didn’t work for me.
I’ m not saying that this guide is not tested or doesn’t work, I only say it didin’t work for me. I’m only trying to help anyone in the same situation. You can see that I tried the exact configuration from this guide and my results are not the same as yours. And I didn’t change absolutely anything, I just followed the guide step by step.
Really, I just wanted to help. If that is not acceptable, please delete my messages.
Regards.
Angel
Sorry, @nerd, but that’s not true. I folloed the guide exactly. And I mean EXACTLY. And it didn’t work for me. I used the [pi4] and the [all] sections, but what worked for me was what I wrote, not the configuration with those tags.
I’ve been trying to make this all work for more than a month, and you know it because you answered me in the Beta thread. Do you think that I would skip trying this guide instructions when they appeared? I didn’t.
I’m really sorry if this has annoyed anyone, that was not my intention. And again, if you think you should, please delete all my messages.
Regards.
Angel
Hey @Mustang65,
Observation: Kernel log shows video=DSI-1:400x - truncated. Should be video=DSI-1:400x1280e,rotate=270. No rotation without full parameter.
Working theory: Allo Katana overlay combined with dtparam=audio=off in your userconfig.txt creates conflicting audio parameter injection, ballooning cmdline length and truncating your video= parameter.
Test: Remove dtparam=audio=off from userconfig.txt:
[pi4]
disable_overscan=1
[all]
Reboot, then provide:
  1. cat /proc/cmdline
  2. fbset
Hey @aluisperezh,
No need to delete anything - your input is valuable. But “it didn’t work” without current diagnostic data leaves nothing to investigate.
Please provide from your CURRENT working setup:
  2. cat /boot/userconfig.txt
  3. cat /boot/cmdline.txt
  4. cat /proc/cmdline
  5. fbset
What you have working now may reveal what the guide needs to address for Pi4 Rev 1.5 specifically.
Hi @nerd
i removed the parameter from userconfig.txt.
Here are the ssh-outputs:
volumio@volumio2:~$ cat /proc/cmdline
coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=1 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:F6:56:9D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyS0,115200 console=tty1 imgpart=UUID=2fcd4aa9-19da-4188-a556-3009b8a5e64a imgfile=/volumio_current.sqsh bootpart=UUID=DFF5-D140 datapart=UUID=08d6ed05-4edb-44af-8ed0-2ea18b54c960 uuidconfig=cmdline.txt pcie_aspm=off pci=pcie_bus_safe rootwait bootdelay=7 logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0 nodebug use_kmsg=no video=DSI-1:400x1280e,rotate=270
fbset
mode "400x1280"
endmode
Display is still dark!
Best regards
for completeness, here the userconfig.txt:
# Add your custom config.txt options to this file, which will be preserved duri>
[pi4]
disable_overscan=1
[all]
Hey @Mustang65,
Good news - the video= parameter is now complete, so the cmdline truncation issue is resolved.
However, display still dark means something else is wrong. This is now a methodical debugging session - every detail matters.
Before collecting diagnostics, perform a full power cycle:
  1. Shutdown Volumio completely
  2. Disconnect power
  3. Wait 30 seconds (power starvation - clears hardware state)
  4. Reconnect power and boot
Then provide:
  1. Log link from http://volumio.local/dev (or http://<your_volumio_IP>/dev)
  2. Loaded strings:
sudo vcgencmd get_config str
The guide was created and tested on Pi 4 with the 7.9" DSI panel - same as your setup. It works. Something specific to your configuration is different. We find it by comparing facts, not guessing.
Hi @nerd
i did a shutdown and power disconnect, waited about a minute, reboot again and here is the link for log file:
http://logs.volumio.org/volumio/i5Ukyzy.html
and this came out in the ssh:
volumio@volumio2:~$ sudo vcgencmd get_config str
device_tree=-
overlay_prefix=overlays/
ramfsfile=volumio.initrd
hdmi_cvt:0=
hdmi_cvt:1=
hdmi_edid_filename:0=
hdmi_edid_filename:1=
hdmi_timings:0=
hdmi_timings:1=
