[GUIDE] SR Radio Sweden | Sveriges Radio channels.
Download SR.zip file from:http://invalid.ed.ntnu.no/~geirhell/SR.zip
Extract file and put the folder SR in: /var/lib/mpd/music/WEBRADIO
If no sound it can be the mpd version, upgrade this by: sudo apt-get update sudo apt-get install libmikmod3 wget http://repo.volumio.org/Packages/Mpd/mpd_0.19.9-2_armhf.deb sudo dpkg -i mpd_0.19.9-2_armhf.deb sudo apt-get -f install
Regards,
Geir H. Pedersen
