[GUIDE] Running Volumio under Proxmox
To preface this, Volumio does not have official support for virtualization. As such, the project’s developers have no obligation to help you if you run into issues and are very unlikely to do so. This is because virtualization introduces factors that do not exist on standard Raspberry Pi or x86 installations. Remember, this is an extremely niche use case for an already fairly niche embedded OS
I am writing this guide as while I could find threads asking about the process and common issues with running Volumio this way on the forum, very few had any useful information and none gave instructions for the full process, particularly with one extremely crucial step that I only found while looking into other music streaming options. With that out of the way, here’s the guide.
Before doing anything else, ensure that you have IOMMU enabled in your systems BIOS. This is part of the crucial step mentioned above, as without it you will experience clipping in the audio.
Once that’s enabled and Proxmox is booted, navigate to the web UI and enter the instance’s shell to run the following commands:
apt install unzip
wget [insert link to latest version of the Volumio x86 image from the download page]
unzip Volumio-[insert version here]-x86_amd64.zip
qemu-img resize -f raw Volumio-[insert version here]-x86_amd64.img 16G
Once you have done this, create a VM. For the most part, the default settings are good, but you need to make a few changes:
  • Under OS tick “Do not use any media”
  • Under Disks delete the default scsi0 drive
  • Under CPU set the type to “Host”
  • If you intend to use any hardware intensive plugins such as FusionDSP or LMS you may increase the number of CPU cores, otherwise it’s fine to keep it at 1 and increase the count later if necessary.
  • Finalize the VM, but do not start it just yet
Make note of the VM ID and the name of the storage pool used for VM disks (local-lvm by default) and return to the instance’s shell to run the following command:
qm importdisk [VM ID] Volumio-[insert version here]-x86_amd64.img [storage pool]
Then navigate to the hardware tab under the Volumio VM to do the following:
  • Click “Unused Disk 0” in the hardware list, then click Edit at the top
  • Set Bus/Device to “SATA” and 0, then click Add
  • Click Add at the top, then select “PCI Device”
  • Select “Raw Device,” under Device select your USB controller, then click Add
    ** This can vary from motherboard to motherboard, but on my own system the CPU’s USB controller is used for the back panel USB ports while the chipset’s USB controller is used for the front panel USB ports.
    ** If you have USB devices passed through to other VMs, make sure to have your DAC connected to a separate USB controller, as everything connected to the controller you select here will get passed through to Volumio instead.
    ** We do not pass through the DAC as a USB device here because Proxmox’s standard method for passing through USB devices causes clipping. This is also why we enable IOMMU at the start.
Navigate to the options tab under the Volumio VM to do the following:
  • Click “Boot Order” in the list, then click Edit at the top.
  • Enable “sata0,” drag it to the top of the list, then disable all other options before clicking OK
  • If you’d like for the VM to start when Proxmox boots up, click “Start on Boot” in the list, click edit at the top, then check the box and click OK.
At this point you may start the VM, the set up process is the same as on a standard Raspberry Pi or x86 installation from this point forward. If your USB DAC doesn’t show up in the device list, change the USB controller that you have passed through to the VM under the hardware tab, then restart the VM.
Thank you. I have followed your instructions and adjusted my own VM settings for it to boot using UEFI. I have also deployed the Volumio VM thru Proxmox on a NUC with a J4125 Intel Celeron cpu and I can passthrough my Intel 600 igpu for display.
It is too bad that Volumio hasn’t updated to bookworm as yet…once they do, I’d have the option of using a DisplayLink USB monitor instead. As it stands, I’ve ordered a 7" HDMI display for peppymeter.
@RedEyeNinja Debian Buster is not the limitation, it is the need for additional driver software installation, which still has to be done for Bookworm.
We have no plans to support this out-of-the-box.
You might be able to do this yourself, but this can lead to a failing OTA software update feature.
I’ve went thru the procedure to install the debian DisplayLink drivers and yes, it indeed immediately breaks the Volumio install…can’t even get back onto the web page.
Very unfortunate, but it is what it is.
I’m sorry to come with a stupid question. I need to update my volumio to bookworm. The last time I did something to my system is like 100 years ago. I downloaded (and also tried the link) the image and used balena etcher (like the times before as I remember) but it throws an error (4.005 and 4.011, the one for generic PC, I want to install it on a lenovo thingy with proxmox VE) “RequesMetadata is not a Function”.
I have some trouble understanding what’s going on, since I somehow succeeded in installing proxmox and home assisstant. what am I doing wrong?
Instead of Belena, use Pi Imager
https://www.raspberrypi.com/software/
Thanks for moving my question here. I’m fighting Proxmox right now. Made the necessary BIOS changes, one hint: it’s not “apt install unzip” but “apt-get install unzip” maybe clear to the most here, I had some issues.
I’m continuing.
And of course you need to make the necessary changes to the repositories when you don’t have a subscription (since I’m not a productive user, I don’t)
1 hour later the first music plays. I’m stunned. Thanks!
both ‘apt’ and ‘apt-get’ should be valid, but it’s generally recommended to use ‘apt’ nowadays as it has more user-interactivity and ‘apt-get’ has been deprecated for years. This is why I used ‘apt’ when both setting it up on my own systems and when writing this guide.
Completely missed setting the correct repos though, I had been tinkering with Proxmox for about a month before writing up this guide and had completely forgotten to check if that would affect the installation of Volumio, so sorry about that!
Hi, just wondering if anyone got guest agent working in the VM?
I’ve been using VM + physical multiroom instances for quite a long time but lately migrated to a new proxmox server and want to tidy things up :wink:
Installing qemu-guest-agent works fine but the agent fail to start with a cryptic timeout and ‘depencencies’ message.
Here’s how it looks:
volumio@volumio:~$ sudo /etc/init.d/qemu-guest-agent start
[sudo] password for volumio:
Starting qemu-guest-agent (via systemctl): qemu-guest-agent.serviceA dependency job for qemu-guest-agent.service failed. See ‘journalctl -xe’ for details.
failed!
Here’s the result from journalctl
Nov 21 15:00:24 radio systemd[1]: dev-virtio\x2dports-org.qemu.guest_agent.0.device: Job dev-virtio\x2dports-org.qemu.guest_agent.0.device/start timed out.
Nov 21 15:00:24 radio systemd[1]: Timed out waiting for device dev-virtio\x2dports-org.qemu.guest_agent.0.device - /dev/virtio-ports/org.qemu.guest_agent.0.
░░ Subject: A start job for unit dev-virtio\x2dports-org.qemu.guest_agent.0.device has failed
░░ Defined-By: systemd
░░ Support: Debian -- User Support
░░ A start job for unit dev-virtio\x2dports-org.qemu.guest_agent.0.device has finished with a failure.
░░ The job identifier is 3191 and the job result is timeout.
Nov 21 15:00:24 radio systemd[1]: Dependency failed for qemu-guest-agent.service - QEMU Guest Agent.
░░ Subject: A start job for unit qemu-guest-agent.service has failed
░░ A start job for unit qemu-guest-agent.service has finished with a failure.
░░ The job identifier is 3190 and the job result is dependency.
Nov 21 15:00:24 radio systemd[1]: qemu-guest-agent.service: Job qemu-guest-agent.service/start failed with result ‘dependency’.
Nov 21 15:00:24 radio systemd[1]: dev-virtio\x2dports-org.qemu.guest_agent.0.device: Job dev-virtio\x2dports-org.qemu.guest_agent.0.device/start failed with result ‘timeout’.
Poking around the system doesn’t show anything special.
